Esc's not receiving input and gps not working
I am currently building a quadcopter that has a 3 cell lipo battery, Pix32 V6 autopilot, and a M8N GPS, but the GPS isn’t seeming to work and it is saying “GPS: No GPS” no matter what I do. Also my esc’s are connected to IO 1, 2, 3, and 4 with the receiver connected to RC IN, but when I connect power, the esc’s do nothing, and it won’t let me arm the drone due to the gps problem and it saying “PreArm: Fence requires position” which I think has to do with the gps since it says position in it. I installed the drone software, set the frame type, calibrated the accelerometer, calibrated the leveling, calibrated the onboard mag, and calibrated the radio, but I am not sure about the servo output thing, because I tried changing where motor 1, 2, 3, and 4 were on in but nothing worked.
here are some pictures of it
Also I pre calibrated all my esc’s before and made sure all of them worked on their own, and I don’t think it should matter but my gps is connected to gps 2 since it won’t fit in gps 1 or i2c. And also I know the props are too small but I got them when I had a smaller frame when I first started working on it so I am still waiting on bigger ones.
Is that port configured for GPS in the parameters?
I got a laugh at the photo of the craft. Putting that Flight Controller on that frame is like the old joke “spinners on a Yugo” :slight_smile:
Oh, that helps, I didn’t know you had to configure it, do you know what parameter(s) I have to change?
The uart assigned to that port has to be configured for GPS. Looks like uart8 but confirm that.
Sorry for not replying for 4 hours, I had to go somewhere, but also how do I check that?
nvm found it, it is uart 8
Also some more info about the esc problem:
I have ESC’s 1-4 connected to IO 1-4, and the outputs on my autopilot go (from left to right) RC-IN, RC-OUT, FMU 8-1. then IO 8-1 so it would look like:
RC-IN, RC-OUT, FMU-8, FMU-7, FMU-6, FMU-5, FMU-4, FMU-3, FMU-2, FMU-1, IO-8, IO-7, IO-6, IO-5, IO-4, IO-3, IO-2, IO-1
and I have it so in servo outputs in ardupilot, positions 1-4 are motors, I have tried positions 13-16 but nothing worked, also for all my esc’s I have signal, 5v, and ground connected to the board. I have tried different combinations of servo output positions and connecting the esc’s to different pins, but nothing ever works. Also I know all the esc’s and motors are working fine because I tested them all individually, also I know that my pdb (my drone frame) is working because I tested all the xt60 connections and they are all outputting sufficient power. Not sure if this info helps but hopefully it does.
Oh and some more info, on the top of the autopilot I have 2 labels, FMU and IO and both of them have 3 leds under them labeled
Pwr: power
B/E: Bootload error
Act: Armed/activity
When I turn the power for the drone, on FMU I get solid green for power, flashing B/E most of the time but it slows down or disappears sometimes, and nothing for act, and for IO I get solid green power, solid red B/E when I turn off the power but after a while it stops, and flashing blue for act. Also yesterday I used a multimeter on the 5V and ground pins for IO 1-4 for my autopilot and I got 5v for all of them, but I tried it again and I am no longer getting any power.
