ESC issues on ADS-B carrier board
I am using a Cube Blue H7 flight controller and an ADS-B carrier board. I tried to hook up one ESC and one motor to test via QGroundControl. However, when the main battery was plugged in the motor just beeped & twitched roughly every second.
I did have power going to the carrier board, and power going to the ESC. My ESC had two connectors, one for ground/throttle signal, and one for CANH/CANL. I plugged the ground/throttle signal connector into the servo rail of my carrier board.
So my question is do I need to power the servo rail directly? Or is this a QGC issue? This is my first time so all of the QGC parameters are a bit confusing to me. Thanks.
