I have a quad-copter with an omnibus F4V6 installed on it (with ardupilot loaded) and I am having trouble doing the ESC calibration. My ESC is a 4 in 1 blHeli 60A ESC. So to calibrate it, I plug in the usb, connect to missionplanner, go to the calibration tab, and click calibrate. Then, I unplug the usb and plug in the battery. I do not hear a motor tone when I plug in the battery that is supposed to tell me to unplug it, instead it goes straight to calibration and it doesn’t matter how I place my throttle stick it does the calibration on it’s own, even though I have the min and max PWM set to 0. I am using the normal setting for the esc type, haven’t tried others.
I tested the motors at 5% throttle and they were turning very fast for 5%, I don’t think it should turn that fast. Also tested the motor response to moving the drone when it’s armed and on stabilize mode, and it doesn’t respond that much. I tried powering on the quad and it just spiraled out of control, here’s a video: https://www.youtube.com/watch?v=ZBrpmz0oGC8
Thankfully it’s not totally broken, I suspect the problem is the ESC not properly calibrated.
