I have seen other comments referring to the error “what is set param error. Please ensure your version is ac3.3+”, but no answers that reasonably correct the error.
I have only seen this error in Arduplane and when trying to calibrate the ESC’s in Q-Mode Config for VTOL. And after clearing the error, the ESC’s do nothing after the reboot.
I have made sure that Mission Planner and the firmware for the FC’s are the latest.
The only answer that I have found is, “Ignore it!”, but that does not resolve the problem and the ESC’c are not calibrated.
Is there a fix for this error, or just live with it?
I’m seeing this as well and am equally stumped on how to fix it. My setup:
ArduPlane 4.6.3
Mission Planner 1.3.83 build 1.3.9384.38258 on Debian, connected directly to the autopilot over USB
Mission Planner on Gentoo, connected to MAVProxy forwarding traffic to the autopilot (i.e., I’ve tried this in both a direct-connection-over-USB and via-mavproxy method with no difference in behavior)
Pixhawk Cube Orange w/ ADS-B in carrier board
Tiltrotor “quadplane” with a tri-motor setup in vectored yaw mode
Q_ENABLE = 1
Q_FRAME_CLASS = 7
Q_FRAME_TYPE = 1 (even though this is ignored with …_CLASS == 7)
I did manage to catch an error message in the console from Mission Planner when I clicked the “calibrate ESCs” button:
WARN MissionPlanner.MAVLinkInterface - Trying to set Param that doesnt exist ESC_CALIBRATION=3
Another post (this one) suggested setting ESC_CALIBRATION as well, so I figured I’d go do it myself – but as the MP error indicates, it’s nowhere to be found in the parameter list.
Just a thought but when you run the calibration make sure you’re in a Q mode. Q-Stabilized, or Q-hover. It may not work if the plane is in manual or FBWA, etc.
Sorry about the delay – work got to me, just getting back to this now!
I definitely wasn’t in any of the Q modes before, but trying that now (QSTABILIZE) I’m getting the same result.
However, i did also find this page: ESC calibration — Plane documentation which indicates a different Q_ESC_CAL parameter for use with quadplanes. This parameter exists for me, so I’m going to give this procedure a shot and will report back.
Edit:
Yep, that worked! I used the Q_ESC_CAL=1 option. Be warned, the motors DID move – like the docs say, make sure you remove props!!
