first of all i have an axisflying aurgus spedixf405 stack on an FPV ,but there isn’t a compatible firmware with it so i used a speedybee firmware instead , but i have an issue that is 2 of the motor didn’t work , ihave tried to change the firmware to matekf405 and still the problem is thier , and all of the configuration is right , and its not a hardware issue because i have turned to betaflight and it is working berfectly , so i need some help?
Does it work, when You flash betaflight speedybee target into it? Probably not.
Build targets is not something that You can not randomly choose just because they share same type of MCU.
Thank’s for your time to respond👍🏾, but what can i do if the target of my fc doesn’t exist in ardupilot. I have tried the custom build also the problem still there.
I guess You need to add support for Your FC.
Ok i will try that. Thank you Adam
You might also consider changing FC to something that is already supported. F405 based FC is not that expensive after all.
