ok, I successfully uninstalled the remaining pyenv using brew uninstall pyenv
then re-ran the script
bash-3.2$ ./prereqsscript_20210629a.sh
---------- ./prereqsscript_20210629a.sh start ----------
+ '[' 501 == 0 ']'
+ [[ /bin/bash == *\z\s\h* ]]
+ [[ /bin/bash == *\b\a\s\h* ]]
+ AP_COMPLETION_SCR=completion.bash
+ SHELL_LOGIN=.bash_profile
+ OPT=/opt
+ ARDUPILOT_TOOLS=Tools/autotest
+ ASSUME_YES=false
+ sep='##############################################'
+ OPTIND=1
+ getopts y opt
+ echo 'Checking homebrew...'
++ which -s brew
+ echo 'Homebrew installed'
Homebrew installed
+ echo 'Checking CLI Tools installed...'
++ xcode-select --install
+ ERROR='xcode-select: error: command line tools are already installed, use "Software Update" to install updates'
+ [[ xcode-select: error: command line tools are already installed, use "Software Update" to install updates != *\c\o\m\m\a\n\d\ \l\i\n\e\ \t\o\o\l\s\ \a\r\e\ \a\l\r\e\a\d\y\ \i\n\s\t\a\l\l\e\d* ]]
+ brew update
Updated 1 tap (homebrew/core).
==> Updated Formulae
jupyterlab vulkan-headers zabbix
+ brew install gawk curl coreutils wget
Warning: gawk 5.1.0 is already installed and up-to-date.
To reinstall 5.1.0, run:
brew reinstall gawk
Warning: curl 7.77.0 is already installed and up-to-date.
To reinstall 7.77.0, run:
brew reinstall curl
Warning: coreutils 8.32 is already installed and up-to-date.
To reinstall 8.32, run:
brew reinstall coreutils
Warning: wget 1.21.1 is already installed and up-to-date.
To reinstall 1.21.1, run:
brew reinstall wget
+ PIP=pip
+ maybe_prompt_user 'Install python using pyenv [N/y]?'
+ false
+ read -p 'Install python using pyenv [N/y]?'
Install python using pyenv [N/y]?y
+ [[ y =~ ^[Yy]$ ]]
+ return 0
+ echo 'Checking pyenv...'
Checking pyenv...
++ which -s pyenv
+ echo 'Installing pyenv'
Installing pyenv
+ curl https://pyenv.run
+ bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 285 100 285 0 0 442 0 --:--:-- --:--:-- --:--:-- 441
Cloning into '/Users/mholmes/.pyenv'...
remote: Enumerating objects: 768, done.
remote: Counting objects: 100% (768/768), done.
remote: Compressing objects: 100% (399/399), done.
remote: Total 768 (delta 423), reused 483 (delta 274), pack-reused 0
Receiving objects: 100% (768/768), 411.33 KiB | 2.29 MiB/s, done.
Resolving deltas: 100% (423/423), done.
Cloning into '/Users/mholmes/.pyenv/plugins/pyenv-doctor'...
remote: Enumerating objects: 11, done.
remote: Counting objects: 100% (11/11), done.
remote: Compressing objects: 100% (9/9), done.
remote: Total 11 (delta 1), reused 5 (delta 0), pack-reused 0
Unpacking objects: 100% (11/11), 38.62 KiB | 416.00 KiB/s, done.
Cloning into '/Users/mholmes/.pyenv/plugins/pyenv-installer'...
remote: Enumerating objects: 16, done.
remote: Counting objects: 100% (16/16), done.
remote: Compressing objects: 100% (13/13), done.
remote: Total 16 (delta 1), reused 7 (delta 0), pack-reused 0
Unpacking objects: 100% (16/16), 5.74 KiB | 588.00 KiB/s, done.
Cloning into '/Users/mholmes/.pyenv/plugins/pyenv-update'...
remote: Enumerating objects: 10, done.
remote: Counting objects: 100% (10/10), done.
remote: Compressing objects: 100% (6/6), done.
remote: Total 10 (delta 1), reused 6 (delta 0), pack-reused 0
Unpacking objects: 100% (10/10), 2.77 KiB | 472.00 KiB/s, done.
Cloning into '/Users/mholmes/.pyenv/plugins/pyenv-virtualenv'...
remote: Enumerating objects: 57, done.
remote: Counting objects: 100% (57/57), done.
remote: Compressing objects: 100% (51/51), done.
remote: Total 57 (delta 11), reused 19 (delta 0), pack-reused 0
Unpacking objects: 100% (57/57), 35.30 KiB | 178.00 KiB/s, done.
Cloning into '/Users/mholmes/.pyenv/plugins/pyenv-which-ext'...
Unpacking objects: 100% (10/10), 2.92 KiB | 497.00 KiB/s, done.
WARNING: seems you still have not added 'pyenv' to the load path.
# (The below instructions are intended for common
# shell setups. See the README for more guidance
# if they don't apply and/or don't work for you.)
# Add pyenv executable to PATH and
# enable shims by adding the following
# to ~/.profile:
export PYENV_ROOT="$HOME/.pyenv"
export PATH="$PYENV_ROOT/bin:$PATH"
eval "$(pyenv init --path)"
# If your ~/.profile sources ~/.bashrc,
# the lines need to be inserted before the part
# that does that. See the README for another option.
# If you have ~/.bash_profile, make sure that it
# also executes the above lines -- e.g. by
# copying them there or by sourcing ~/.profile
# Load pyenv into the shell by adding
# the following to ~/.bashrc:
eval "$(pyenv init -)"
# Make sure to restart your entire logon session
# for changes to profile files to take effect.
# Load pyenv-virtualenv automatically by adding
eval "$(pyenv virtualenv-init -)"
+ exportline='export PYENV_ROOT=$HOME/.pyenv'
+ echo export 'PYENV_ROOT=$HOME/.pyenv'
+ exportline='export PATH=$PYENV_ROOT/bin:$PATH'
+ echo export 'PATH=$PYENV_ROOT/bin:$PATH'
+ evalline='eval "$(pyenv init --path)"'
+ echo eval '"$(pyenv' init '--path)"'
+ evalline='eval "$(pyenv init -)"'
+ echo eval '"$(pyenv' init '-)"'
+ source /Users/mholmes/.bash_profile
++ export PATH
++ source /Users/Tools/completion/completion.bash
/Users/mholmes/.bash_profile: line 2: /Users/Tools/completion/completion.bash: No such file or directory
bash-3.2$
this is the current contents of my .bash_profile, in case that’s relevant to the new error:
export PATH
what’s with the completion.bash file? I’ll do some more self-educating
