Error with Speedybee AIO F405 Battery Monitor
The current monitor works perfectly. But Volt Monitor doesn’t work.
please share more details like software settings.
maybe your calibration is wrong or the pin is not correctly set
I follow exactly as per here SpeedyBee F405 AIO 40A Bluejay — Copter documentation
Doesn’t work. It’s a new FC. Then after fiddling around. I think maybe because it’s the new firmware
So I install 4.6.0 Still doesn’t work.
Gave up I install Inav. And it work.
Obviously something wrong with the settings.
