Error with Flywoo 745 AIO v3 (with ICM) orientation
So I followed exactly as per this.
Frame 12, Class 1. Orientation 5.
Firstly orientation 5 it is not correct.
Secondly Problem is the pitch seems to be wrong direction. When I set it at Zero degrees orientation, my rolls are fine, but pitch is the direct opposite. I set the yaw at 180 then pitch is correct but roll is wrong. there don’t seems to be a right way of setting this orientation.
I had some of the Flywoo AIO from early last year they are ok. But current batch I got seems to have this problem when installed with ardupilot. It works fine on Betaflight though.?
Any solution to invert the pitch?
Which version of this AIO You have? Orientation change is only for one of versions:
The AIO V3 has its IMU at a different orientation to V1.2. This means AHRS_ORIENTATION = 5
Hi I am with V3.
For some reasons I bought one v3 earlier with mp6000 it works well.
But the latest v3 with ICM has this issue.
I improved the post title.
