This time I loaded the raw, original plane_aerobatics.lua on the sd card and I activated the scripting in ardupilot.
When turning on the flight controller I get the error
Lua: /APM/scripts/plane_aerobatics.lua:287: No par
Looking into the script at that line, Ardupilot is failing to load the parameter “MAV_SYSID”.
According to documentation, it is actually missing among the available parameters in latest stable version of Plane: V4.6.3
What to do so?
Thanks
Adriano
Found the solution!
I just retrieved the file from the 4.6.3 repository and it works!
Yuri_Rage
(Yuri Rage)
3
Yes. If you download from the master branch, there’s a good chance it will be incompatible. 4.7 is staged to introduce a fair amount of change.
