I had done some .px4 and I also had by the past erros about submodules (Mavlink going “dirty” and couldn’t find a solution so I simply deleted it and I could use the function “make px4” again.
But now the error was on PX4 Firmware module so I couldn’t delete the folder.
I had an Error 2
I tried copying from the clean repository online only the modules and I did the
git config --global core.autocrlf false
and
git submodule update --init --recursive
again and now I have an error 1
I saved the fromer “Modules” folder so I can go back to it if required
On Github I am working on my branch I I did a merge to master but I came back on my branch.
It’s been 2 hours I am stucked now and I tried many solutions on forums and even on ardupilot one
hope someone can help me
Edit : I also tried “git submodule init”, “git submodule update”
The path to uavcan looks very long and wrong. I would suggest
Go to your Ardupilot/modules folder and delete uavcan subdirectory from it ( In fact it is ok to delete all subdirectories I believe if you prefer). then in Ardupilot directory type git ‘submodule init’ and ‘git submodule update’. You should see the modules being downloaded again and you should be back on track.
@maelito
It is really annoying that a build affects the mavlink module. Ideally whatever is buiit should be done in another directory away from the module deirectory. I assume that would fix it
