@rmackay9 Had internal error 0x10000000 on 4.1.5 this morning. I checked and all params should be ok, does it mean it recovered from a backup and i am all ok?
internal error 0x10000000 param 365 was the entire message
Also noticed that under APM/STRG_BAK directory in the cube i have 99 files STRGXX.bak
I have seen that too, seems like the kore is one of the worst for that prob. It is a shame because is great for everything else. Maybe it is the way the tension raises when powered that alters something.
I do not have a bin file because it was not active since it is a new drone.
Thank you for your help, hope the mitigation does its job
