Erroneous pre-arm message ref CAN
I’m getting a pre-arm message “PreArm: DroneCAN: Duplicate Node TM101_V60_V1../7!” - I have 7 of these T-Motor CAN ESCs (TM101_V60’s), but they are definitely not on duplicate nodes, so the message is in error.
Is this a bug I need to report?
What are the node ids?
Did you tried look up what the error message means ?
Thank you Eosbandi! I thought the error message was pretty clear, but wasnt aware of the solution, thanks.
