Elrs AUX Channels "lagging"
I am having trouble with the AUX channels “lagging” or not updating as fast as channels 1-4, specifically channel 6 which I am using for a flaperon. Switch mode is set to Wide. When using lower packet rates between 50-150hz the servo is only updating its position once or twice per second. when using 250hz or above the problem largely disappears. This is not a problem for channels 1-4.
Has anybody else had this problem/fixed this before?
I just changed the Packet rate to “100 full” and the problem went away. I understand now that you have to use a “full” width channel in order to get the full resolution. Noob mistake, sorry.
It is good to have flap slew rate limited as it slows down trim change during deployment/retraction, then you can use low resolution channel for flap operation.
