Hi guys!
I’m a longtime APM:Copter user building up my first flying wing! I’m stuck on a problem that I need some help with.
Currently, when I push pitch forward on my RC control (in Manual of FBWA), the elevons both move down as expected, pushing the plane’s nose down. When I switch into FBWA mode, and I rotate the plane’s nose down, both elevons also move down. I believe this is incorrect, I’d want the elevons to move up above the wing to counter the nose’s rotation.
(I assume orientation is as if you’re sitting in the cockpit, so looking down the nose of the plane).
- I have a flying wing setup with a APM2.6 board running the latest ArduPlane 3.2.
- I’m using a FlySky TH9X radio with a D4R-ii receiver in PPM mode.
- The right elevon is connected to Output CH1
- The left elevon is connected to Output CH2
- The motor to CH3.
- The transmitter has elevon mixing set up, so I can fly in manual mode just fine.
Any ideas guys?
