Thanks for the report. So this appears to be that the SpeedyBee is running out of memory which is definitely not a good thing.
I’m actually surprised that you were able to arm the vehicle. Has the ARMING_CHECK parameter been set to zero? If “yes” then it would be good to restore this to “1”.
Now that you can get logs off the vehicle, could you provide an onboard log of one of the 4.6 flights? The F4 boards are definitely reaching there limits but maybe we can remove some default features to free up some memory
Thanks for the reply.
Arming_Check was set 1 and I did not have any problems arming.
Sorry the files were presented but held rubbish so i deleted them!
During the test flight all seemed normal in bets5, it was only after I tried to view the files that the DataFlash Logs windws reported that there was no files!
I could only see them after I revereted to 5.7.
Agin sorry i can’t be more helpful.
