Process of occurrence:
- The aircraft’s self stabilizing mode is unlocked for takeoff, and everything is normal at this time;
- After about 10 seconds of flight, and sometimes even longer, the plane begins to deviate in one direction. At this point, it is necessary to adjust the joystick to correct the plane
- After landing, the plane is placed on a horizontal plane, and the horizon seen in the hud has a tilt ranging from 0.01 to 0.07, but at this time the plane is physically level
- After a while (the time is not fixed), the ground plane starts to move in an inclined direction in the hud. When it reaches a certain position, it triggers: ekf3 imu0 forced reset; At this point, hud returns to a horizontal position
