Is there a specific reason why entering AID_NONE also requires a direct write to the Z state from baroDataDelayed.hgt?
In other words, why should loss of XY aiding directly overwrite stateStruct.position.z, instead of leaving the vertical state under the normal height-source manager?
As a premise, yes, I did use AI assistance when writing the post. The intention was mainly to make the explanation as clear and technically structured as possible, and especially to help me correct my English where needed.
The technical analysis, logs, Replay tests and conclusions are based on the actual data and source investigation.
In any case, I understand your point. From now on I’ll try to keep my questions much shorter and more focused.
