Loweheiser
(Fernando)
September 30, 2020, 11:42am
#1
Hi!, We are interested in testing EFI support in software V4.1.0dev
https://ardupilot.org/plane/docs/parameters.html#efi-parameters
We found it very interesting that Ardupilot has EFI support because for some combustion engines applications is necessary.
We are developing this EFI for drones, it is a very small and light EFI. We have made a solution to have telemetry in QGC without needing to modify the firmware, using COMMAND_LONG message.
Could someone help us to compile the V4.1.0dev
Or where can we download?
First you need to convince @tridge to merge: https://github.com/ArduPilot/ardupilot/pull/15404
After that the support for that message needs to be extended.
jlcortex
(jlcortex)
September 30, 2020, 3:51pm
#3
but, It is merged into master, Is it?
ArduPilot:master
← ArduPilot:pr-efi-extensions
opened 11:14PM - 31 Dec 19 UTC
Now we’ve already test the V4.1.0dev into the board, and the list of parameters don’t show the EFI ones
This is the version of the mission planner, could be that the problem?
No, that is not the problem, but you should update to the latest mission planner anyways.
To solve you problem you need to enable EFI_TYPE to 1 and refresh the parameters. The other parameter will appear just fine after that.
Alf9492
(Aflonso)
November 26, 2020, 4:00pm
#7
Hi everyone!
I have the lastest version of mission planner(1.3.74 biuld1.3.7.7563.27684).
I my case, I have tested arduplane and arducopter (Both of them at v4.1DEV) but at the parameter list ECU_TYPE don’t appear.
Where could I get access to this parameter?
Regards!
ECU_TYPE is not the correct parameter. The correct parameter is EFI_TYPE.
What hardware board are you using? is the mission planner set to show advanced parameters?
Alf9492
(Aflonso)
November 27, 2020, 7:27am
#9
Sorry, I wanted to say “EFI_TYPE”.
Yes, I type EFI_TYPE and “Full Parameter List” windows and I dont found nothing
Hardware version in unimportant. FW versions are important.
jlcortex
(jlcortex)
February 25, 2021, 7:14am
#12
I see that the EFI channels are not in the “Display this” so the only way to see them is to open the Mavlink inspector
Is there a way to add them to see them on the main screen?
Ask that on the missionPlanner topic
