Dear All,
In ArduPilot, I am switching the EKF source mode (SRC) while the drone is in motion. Initially, I arm and take off in Guided mode using GPS. When I later switch to Beacon-based positioning (tested with both Beacon SITL and Pozyx), sudden jumps occur in the drone’s actual position.
Solutions I’ve tried
- I tried to perfectly match the beacon origin parameters (BCN_LATITUDE, BCN_LONGITUDE, BCN_ALT) with the ArduPilot home/origin (SIM_OPOS_*) values, but I’m still experiencing discrepancies.
- I was switching from GPS to Pozyx (BCN_TYPE = 1). Thinking Pozyx might be faulty, I tried Beacon SITL (BCN_TYPE = 10). However, the jump is still happening.
- When I try to set the first SRC (SRC1) source as Beacon and the second SRC (SRC2) source as GPS, I get the error “AP Arm: GPS and AHRS differ by 12.3m” without the drone even being able to lift off.
I am performing the SRC source change with the following simple code.
from pymavlink import mavutil
# Connect (typical address for SITL)
master = mavutil.mavlink_connection("udp:127.0.0.1:14550")
master.wait_heartbeat()
print("Connected:", master.target_system, master.target_component)
def set_src(src):
print(f"Switching to SRC {src}...")
master.mav.command_long_send(
master.target_component,
42007, # MAV_CMD_SET_EKF_SOURCE_SET
0,
src, # param1 = source set (1,2,3)
0, 0, 0, 0, 0, 0
ack = master.recv_match(type="COMMAND_ACK", blocking=True, timeout=3)
if ack and ack.result == 0:
print("OK")
else:
print("FAIL", ack.result if ack else "No ACK")
while True:
s = input("Select SRC (1/2/3, q to quit): ").strip()
if s == "q":
break
if s in ["1", "2", "3"]:
set_src(int(s))
EKF Source Configuration
| Parameter | Value | Description |
| EK3_SRC1_POSXY | 3 | GPS |
| EK3_SRC1_POSZ | 1 | Barometer |
| EK3_SRC1_VELXY | 3 | GPS |
| EK3_SRC1_VELZ | 3 | GPS |
| EK3_SRC1_YAW | 1 | Compass |
| EK3_SRC2_POSXY | 4 | Beacon |
| EK3_SRC2_POSZ | 1 | Barometer |
| EK3_SRC2_VELXY | 0 | None |
| EK3_SRC2_VELZ | 0 | None |
| EK3_SRC2_YAW | 1 | Compass |
| EK3_SRC3_POSXY | 0 | None |
| EK3_SRC3_POSZ | 1 | Barometer |
| EK3_SRC3_VELXY | 0 | None |
| EK3_SRC3_VELZ | 0 | None |
| EK3_SRC3_YAW | 0 | None |
| EK3_SRC_OPTIONS | 8 | UsePerCoreEKFSources |
Beacon & Simulation Origin Parameters
| Parameter | Value |
| BCN_ALT | 584.0 |
| BCN_LATITUDE | -35.36326217651367 |
| BCN_LONGITUDE | 149.1652374267578 |
| BCN_ORIENT_YAW | 0 |
| BCN_TYPE | 10 |
| SIM_OPOS_ALT | 584.0 |
| SIM_OPOS_HDG | 353.0 |
| SIM_OPOS_LAT | -35.36326217651367 |
| SIM_OPOS_LNG | 149.1652374267578 |
ArduPilot Version
Vehicle: Copter
Release: Copter-4.5.7
Commit: 2a3dc4b7bf2507120f7378a7b2fde73185e0c325
