Dual gps hardware
I have build a 15inch drone only holybro x650 frame iam planning to fly for long range about 10km+ now for primary gps iam using Holybro unicore um982 for gps yaw and position. I am planning to set a secondary gps however I can’t enable gps blending because gps yaw is active. Which hardware to choose for secondary using another holybro um982 or cube pilot here4 which unit shall I choose i have confusion in thsi
I think your best bet is likely GPS_AUTO_SWITCH,4 (“Use primary if 3D fix or better”) with GPS_PRIMARY set to the UM982. Then add any good, performant single antenna module (Here4, UM980, Zed-F9P, etc) as a backup. In the event that the primary module fails, you at least still have position from the redundant module.
Since the redundant module is position-only, keep a calibrated compass enabled and set EK3_SRC1_YAW,3 (“GPS with compass fallback”).
Don’t enable blending (GPS_AUTO_SWITCH,2). From a look at AP_GPS_Blended.cpp, the blended virtual instance never populates the GPS yaw fields, so the EKF will never see GPS yaw with blending enabled.
A second UM982 can technically work, but auto switching won’t happen on lost heading (only bad fix). I’m not sure how much testing has been done with dual-UM982 configs, and it’s likely a case of diminishing returns to have that many antennas and that much expense in a redundant module.
