Dshot ESC's Refuse to connect
Morning guys, first time ever setting up an autopilot on on a plane as I’ve always flown manual, I’m having trouble with a vtail twin puller. The esc’s are 2 sequire 8s 120a am32 escs that are both freshly configured, and they are hooked up to s1 and s2 of the fc, which is a matek h743wlite.
The wiring is good, i’m not using any telemetry wire however, just the ground and signal, i have checked the connection several times and even ran continuity from one end to the other in case of a frayed wire but no result, leading me to it being a config error. i was told to run the escs at dshot 150, as I am running 2 13 inch props on 3115 motors, and apparently it makes them run more efficient?
The motor test page is also grayed out, even when armed and force armed.
I’ve attached the params file down below along, If anyone could take a look and point out any errors it would be greatly appreciated.
Falcon_Arming_Issue_Config.param (21.2 KB)
