DShot and Mavlink Servo out
When I set servo/esc out to DShot Protocol no usable servo out values arrive via mavlink. Is there another mavlink parameter that says something about ESC control in this case?
@webmotions,
Thanks for the report. So I guess you’re not seeing the output in MP’s status screen?
I wonder if it’s possible that the issue is that the DShot ESCs are connected to a channel that is higher than 8 and these are only reported if Mavlink2 is used. Could you try setting the SERIALx_PROTOCOL to “2” for the telemetry connection being used?
Another way to check this last suggestion is to connect with a USB cable to the autopilot because the direct USB port is always Mavlink2.
yes you are right. I’m using aux 9-12 for dshot out. In MissionPlanner with USB Connection i can see the values. With Cube Orange it should also be possible to use servo 1-4 for dshot?
No, you need to use the aux outputs. Just make sure the telemetry is mavlink2.
