I am encountering an issue where the drone’s yaw consistently drifts to one side (yawing to the left) after applying the parameters generated by the MagFit tool.
Issue Summary:
• Stock / Original Parameters: The drone holds its yaw heading without any issues • Post-MagFit Parameters: After running MagFit (which I have attempted using multiple approaches and variations), the drone starts steadily drifting/yawing towards a lower vaw angle.
Had no problems doing magfit tool calibrations with my othere drones.
Software notwithstanding, this can be a cause of a warped prop or motor twist. I would also check the FC for level, at times you can slightly rotate the craft to opposite of the drift then level as well. In Cabinet making we use what called " winding sticks" the sticks allows you to sight the arms.
“Winding sticks are a pair of matching parallel straightedges used in woodworking to detect and exaggerate twist or “wind” in a board. When placed on opposite ends of a piece of lumber, sighting across their top edges makes any angular deviation or unevenness immediately visible to the eye”
