Drone took off by itself
“But if it didn’t start the Auto Mission when you raise the throttle that could be due to a few different issues.” Overall not a huge deal for me just curious. At this time if i am in the air it will go to Auto. Edit: Second thought i’m testing in Plane. I think i can add a take off setting that could do it. I’l give that a try in the sim.
For safer flight, set these:
BATT_FS_CRT_ACT,1
BATT_FS_LOW_ACT,2
PILOT_THR_BHV,7     // I see you already had 1
Definitely DO NOT power off the RC transmitter before the copter is powered off - always power on the transmitter first too.
I see you are using SBUS, so that’s good. And the radio failsafe is working.
I could not see any other reason for the “uncommanded” flight except the copter was not fully disarmed and the transmitter must have still been on when you placed it down. There were definitely stick inputs around 09:19.36
After the copter took off, radio failsafe changed the mode to RTL, which may have been caused by the transmitter finally powering off.
Also try setting DISARM_DELAY,6 just because I’ve found any smaller values usually do not make any noticeable difference. Better to expect 6 seconds and get it, than expect 3 seconds and not achieve it.
EDIT:
You do not have AUTO_OPTIONS set to allow arming in Auto mode, so that’s good.
New edit:
Output to motors was stopped, so the copter was definitely disarmed - it must have been an unfortunate movement of those RC sticks to arm the copter.
