Drone jello on Holybro X500 V2
I’m using the Holybro X500 V2 kit and i’m having some issues with it.
At first it was flying fine but then I flashed Bluejay v 0.21.0 on them in order to get rpm telemetry for notch filtering later. I noticed the drone shaking now while i’m flying. After trying to check the settings for the bluejay configurator I keep getting the error message “the port is already in use by another application try re-connecting.” The port is not used by methodic configurator or ardupilot at all. The same issue happens when i try to connect to the esc’s via blheli-configurator.exe: Connection failed, ensure that you have selected the correct port or restart your device.
Thanks in advance!
Reboot the PC and the FC.
I tried rebooting the pc => going to bluejay configurator with chrome. Then plugging the FC in and still the same issue appears. When plugging in the fc appears as COM6 and COM7, could that be an issue?
I’m thinking i might messed up the bluejay flash and that causes the vibrations and made the esc’s unreadable. I hope that’s not the case tho.
Thanks on regards
the bluejay firmware has more aggressive reactions with stronger brake and acceleration so your previous tune is now invalid.
Okay thanks! I will retune then.
