Drone is vibrating up and down only not aggressively and causing magnetic interferance
The rapid oscillation or “shaking” you are seeing in the video—and hearing from the rapid pulsing of the motors—is a classic sign of a tuning or vibration isolation issue. Since the drone moves properly on its axes (left/right, up/down) but shakes continuously, the core control loop is functioning, but the flight controller is overcompensating.
As i did MOtorCompass Callibration, PID tunning also tried each ans everything if anyone have specific solutions tell me
This is a classic. Happens to lots of users that do not follow all the instructions on the wiki and/or do not follow them in the correct order.
The solution is to read and follow the instructions more carefully or
you can use the AMC software to guide you step-by-step in the correct sequence to fix your vehicle.
