Drone Drifting in Loiter Mode During Radio Failsafe
Dear ArduPilot Community,
First of all, I apologize if my English is not perfect as I am not a native speaker.
I am facing an issue where my drone starts moving slowly (about 1 m/s) instead of staying stationary when I switch to Loiter mode via Mission Planner during a Radio Failsafe (FS) condition. The GPS status was “RTK Fixed,” so I believe there are no GPS-related issues. I confirmed that RCIN1-4 was in a neutral state when the transmitter is turned off.
This behavior was observed under various FS_THR_ENABLE settings “always RTL”,“always Land”, and “always Brake or Land”. When, FS_THR_ENABLE is “disabled”, the behavior wasn’t occured.
The ArduCopter versions I tested are V4.5.7 and V4.3.7.
Could you please let me know what the problem is?
Below, I have provided detailed flight logs and the steps I performed during testing.
Flight Logs and Observations -----------------------------
Flight 1 (flt1)
FS_THR_ENABLE : Always RTL
  • 11:41:00 ~ : While flying in Loiter, switched to RTL via Mission Planner, then back to Loiter via the transmitter. The drone remained stationary. (Transmitter was always turned on)
    *11:41:50 ~ : While flying in Loiter, switched to RTL via Mission Planner, then back to Loiter via Mission Planner. The drone remained stationary. (Transmitter was always turned on)
    *11:43:25 ~ : While flying in Loiter, turned off the transmitter. FS triggered RTL. Switched back to Loiter via Mission Planner. The drone started moving.
Flight 2 (flt2)
  • 11:45:30 ~ : While flying in Loiter, turned off the transmitter. FS triggered RTL. Switched to Brake mode via Mission Planner. The drone remained stationary.
  • 11:46:40 ~ : While flying in Loiter, turned off the transmitter. FS triggered RTL. Switched to Brake mode via Mission Planner, then back to Loiter. The drone started moving.
  • 11:49:20 ~ : While flying in Loiter, turned off the transmitter. FS triggered RTL. Switched back to Loiter via Mission Planner. The drone started moving.
Flight 3 (flt3)
  • Triggered Battery FS by increasing FS voltage threshold. Switched to Loiter via Mission Planner. The drone flew stationary.
Flight 4 (flt4)
  • Triggered Battery FS by increasing FS voltage threshold. Switched to Loiter via the transmitter. The drone flew stationary.
Flight 5 (flt5)
FS_THR_ENABLE: Disabled
  • 14:35:06 ~ : Turned off the transmitter and tested RTL and Land modes. Both worked as expected.
  • 14:37:00 ~ 14:38:00: At some point during this timeframe, turned off the transmitter. The drone remained stationary.
  • 14:37:25 ~ 14:38:45: Turned off the transmitter while RC1 (Roll) was actively inputted. Despite the FS settings on the transmitter, RCIN1 values remained fixed.
Flight 6 (flt6)
  • Turned off the transmitter, then switched to RTL via Mission Planner, and subsequently to Loiter. The drone remained stationary.
Flight 7 (flt7)
FS_THR_ENABLE: Always Land
  • Turned off the transmitter. FS triggered Land mode as expected. Switched to Loiter via Mission Planner. The drone started moving.
Flight 8 (flt8)
FS_THR_ENABLE: Always Brake or Land
  • Turned off the transmitter. FS triggered Brake mode. The drone remained stationary.
  • Switched to Loiter mode via Mission Planner. The drone started drifting.
  • Repeated this test five times, and the behavior was reproducible.
Thank you very much for your support!
Best regards,
The link doesn’t work.
I’m sorry. The access settings was wrong. I fixed it, so could you please check it?
Looks like velocity target isn’t set to 0 correctly. We probably should improve rejecting pilot modes when there is no valid pilot input.
PS IIRC Mission Planner warns against setting pilot control modes when in RC failsafe.
Thank you for your response.
I understand that setting the loiter mode during RC failsafe is not specifically intended and can lead to unexpected behavior.
I will make sure not to set the pilot control mode during RC failsafe.
