The dps310 is a very good baro, way better than MS5611.
It worked with AC 4.0.5 , one had to set GND_PROBE_EXT=64 (64 is the code for dps280, which was obviously compatible).
That doesn’t work anymore in AC 4.1.3 Baro is not found.
Does anyone know a workaround to get it working ?
DPS310 is supported natively, you shouldn’t have to set anything to get it to work. Many boards use this baro
