Hi @rickyg32 ,
Did you disable obstacle avoidance for the downward facing lidar? Is there any parameter to disable it only for the downward facing LiDAR ? If the obstacle avoidance is on, how does it land when it is very close to the ground ? Doesn’t it simply avoid the ground ? I am just confused a bit. It would be great if you can help me out .
you can do this with a lua script, just set a switch to change the downwards facing rangefinder maximum range parameter to something very small like 3cm so its ignored by the proximity.
