I would like to request this feature
For two minutes of flight time, one needs a beefy slingshot and a small parachute. Why bother with a multicopter !?
Exactly what are you flying? I have an FPV Whoop that gets a lot more than two minutes on 300mAh 1S battery. Pictures are worth a thousand words…
Yeah ur right but it is some kind of a mission-racing drone type of thing so yeah.
By the way guys what are the ATC_ACCEL_P_MAX and ATC_ACCEL_R_MAX Values for 5 inch props
Could you please explain this solution a bit more
Set AUTOTUNE_AXES=1 and then autotune will only try and tune roll which will be significantly quicker. Do the same for other axes one at a time
No no about the part that I will land the drone down and plug it in with the usb and when I re plug the battery it will fly and continue the autotune process
I’ve never done it before but it apparently works in theory.
BUT - if autotune is taking a long time it could easily be that you have too much noise in your system and need to configure the harmonic notch more carefully. It could also be that the weather is not calm enough and the copter is failing to get level.
I havent done the autotune process but I have watched some videos and they say that it’s minimum of 10 mins on average isnt it true
Mine tunes take about 2 minutes per axis.
And I use the AUTOTUNE_AXES parameter to just do one axis at a time.
Could you please share your setup
I have a custom frame. So no way my parameters will help you.
But I did follow https://ardupilot.org/copter/docs/tuning-process-instructions.html step by step, without skipping a single one! And I did tune the dynamic notch filter. That’s all.
I followed thru that instructions as well as I have stated before I haven’t tried the autotune process and the second thing is I didn’t understand Dynamic notch filter tuning at all could you please help me about it
Please do read the documentation, and ask specific questions.
Roll and Pitch tune completes faster, Yaw is the longest among the three. Make sure the drone body CG is at the center, no wind condition, else many time your battery is wasted to bring the drone back to the place you want the UA to resume the “dance”.
If your drone is small, do an indoor auto tune, one axis by one axis. Also make sure this is completed first. Good luck.
My drone is really small but I’m really afraid of indoor tuning so I have to find a way to make sure my drone completes autotune
Autotune is essentially just hovering. If your multirotor cannot hover for more than 2 minutes, that indicates something seriously wrong with your choice of battery, motors/props, etc. Even if your application is something like a racing drone that is pushed to the limit for 2 minutes, it should still get 6-8 minutes on the exact same battery when just hovering in place for autotune.
Can you share your actual setup? Frame design, motors/props/ESCs, battery, total weight, etc. A photo would be great.
Then stop worrying and Manual tune. You said you followed the Initial Tuning Guidelines so then page down a bit further in the same page to “Manual Tuning of Pitch and Roll” and go for it. I tuned my 1st Arducopter mini quad in about 20 minutes in my garage,
