It looks like the Quiktune Lua script hasnt been updated in about a year on github. From reading the docs as well at QuikTune — Copter documentation , it doesnt look like any params it touches have been renamed. But I want to ask before blindly trying it: Does this work on 4.7 as is? Anything I should worry about before using this?
Same question as well for the magfit helper: Scripted MagFit flightpath generation
In its docs it references using WPNAV_SPEED for example, which has changed to WP_SPD in 4.7. Does this work on 4.7 as well?
After I upgraded a copter with magfit helper on it, it threw some errors I saw in the mission planner console about the wpnav_speed param. So I removed the script and error went away for now.
If the param name is outdated, fixing it would be as simple as find/replace with the updated name. The script is just a text file. I am away from a place where I can test it properly and will not be able to put any time toward it for about a month. @rmackay9, happy if you were to fix it while I’m away.
