DJI O4 OSD configuration
Hi all,
I purchased an O4 Pro transmitter and the DJI Goggles 3 headset, which I would like to connect to the Cube Orange+ autopilot. I tried every way to configure the parameters by following the instructions on the website, on the forum and watching the various video tutorials, but I was unable to display the OSD on the headset.
Can someone help me?
Thanks in advance,
Fausto
Hi Fausto,
Could you share a copy of your parameters?
Is your VTX connected correctly: Gray TX wire to RX on the FC, and white RX wire to the TX on the FC UART?
ETA: Also, which connector are you using on the FC?
Take a look at this thread.
Here’s the main point:
Hi all,
Thanks for the replies. I tried configuring Telemetry Port 2, which should correspond to Serial Port 2, using the parameters suggested by Duane, but I still don’t see the OSD on the Goggles 3. I’ve checked the connections between the O4 unit several times, and they are: pin 3 of the connector on O4 connected to pin 2 of the telemetry port on CubePilot, pin 4 on the O4 unit connected to pin 3 on CubePilot, pin 2 on CubePilot (GND) connected to pin 6 on CubePilot. I power the O4 unit with a separate battery due to its high consumption.
I attach the list of parameters:
Parameter list.param (22.9 KB)
Thanks for reply…
Fausto
It looks like you have everything configured correctly.
Have you tried using a different port (e.g., GPS 2)?
Hi all,
It seems I’ve solved the problem… I needed to set OSD_TYPE = 5 and OSD_TYPE2 = 5… I forgot to set OSD_TYPE2 to 5. Now I need to fix the character layout. On the Goggles 3, you can only select Betaflight or Inav; I selected the former because the characters are garbled with Inav. Now I need to figure out how to fix everything on Mission Planner.
Thanks everyone for your help. If you have any questions regarding radio frequency issues, I’m happy to help.
Fausto
Hi there is the msp_options parameter to check fonts
