Hello. I have built a second Dolphin Pro VTOL, but the low-power mode on the DJI O4 system does not disable when I arm the aircraft.
The OSD displays correctly, but the aircraft voltage is not shown in the bottom-right corner of the goggles, and the low-power mode does not disengage when the craft is armed.
In the previously produced Dolphin Pro VTOL, the low-power mode is correctly disabled upon arming.
The two aircraft differ in their flight controllers: one uses the Matek H743-Wing v3, and the other uses the Holybro Kakute H743-Wing. I am experiencing issues with the aircraft that uses the Kakute. (Both aircraft use ArduPlane 4.7.2.)
I connected the DJI O4 to Serial4 on the Matek, and to Serial2 on the Holybro.
Build using Matek – the system voltage is displayed correctly (red circle), and the low-power mode is disabled upon arming.
Built using Holybro — the system voltage is not displayed, and the low-power mode does not disengage upon arming. (In the photo, the low-power mode was manually disabled via the goggles.)
I don’t think so, or maybe there is more related to that. I was flying a stallion at last 2 years with an O4, and from nothing, the O4 never leaves the Low power mode - I didn’t update anything, changed anything. To test I change from the O4 to an older O3 and was working fine - telemetry and etcs. Then I switch back to the same O4 and nothing. I had to change the O4 to another one and everything was working fine again. I don’t thing is an ardupilot thing, appear to me more an O4 problem - to use this O4 I installed on a drone with the low power feature disabled.
I’ve been advised to check for potential damage to the RX connector on the O4 unit. I plan to disassemble it shortly to investigate. Thanks in advance to everyone!
Yes, I tried everything and I include test with a multimetter the continuos between the o4 board to the flight controller - speedybee wing - and was not any kind of connection problem.
