arduplane3.2 disable CLI by default in build?
How to start the CLI? press ENETR 3 times to start interactive setup is invalid!
thank you
It’s been mentioned a few times on the 3.2 blogs CLI has been removed from apm2 as not enough flash space for it and everything else.
Anything you used to do on CLI is now done through mission planner.
[quote=“MarkM”]It’s been mentioned a few times on the 3.2 blogs CLI has been removed from apm2 as not enough flash space for it and everything else.
Anything you used to do on CLI is now done through mission planner.[/quote]
erase ande reset .Restore the default
thank you!
I need to reset to factory Settings.erase eeprom.How to do?
I’ve added a FAQ entry on resetting parameters to the defaults:
plane.ardupilot.com/wiki/fixed-w … o_defaults
[quote=“tridge”]I’ve added a FAQ entry on resetting parameters to the defaults:
plane.ardupilot.com/wiki/fixed-w … o_defaults[/quote]
Thank you very much
