Hi. I have a stabilized tilt on my tricopter where i have my gopro and FPV Cam mounted.
it is adjusted so that when i give full forward in stabilize mode (aprox 55deg) the tilt compensates so that the camera is pointing almost level (minus about 40deg). i tuned it that way so i have some indication of the actual angle of the craft in the fpc and gopro video.
This is a very nice way to fly fast around trees and other obstacles in stabilize mode and still get a feel for the tricopter pitch angle without only getting the ground in the video.
However when i want to do some acro stuff like flipps and diving from waaay up i would like to turn off the stabilization of the tilt platform. (so that the cameras is aligned forward with the frame) tilt at 0deg always.
i have my own github fork of the apm code with some small changes that i would like to incorporate this inn to.
i dont have a full overview of the apm code and would like to get some hints on where to change this.
i do have some programming skills from Arduino, PHP, C# and VB
I think it should be a simple task to implement. but i don’t know the function to set the camera mode (and it might be overwritten by some other function or a mavlink message if i use the ground station.
in arducopter system.pde
switch(mode) {
case ACRO:
success = true;
set_yaw_mode(ACRO_YAW);
set_roll_pitch_mode(ACRO_RP);
set_throttle_mode(ACRO_THR);
set_nav_mode(NAV_NONE);
[color=#FF0000]SET Mount mode to Retract???[/color]
break;
case STABILIZE:
success = true;
set_yaw_mode(STABILIZE_YAW);
set_roll_pitch_mode(STABILIZE_RP);
set_throttle_mode(STABILIZE_THR);
[color=#FF0000]Re enable Cam Stabelization???[/color]
break;
alternatively this could be implemented with a chan7/8 option to retract the Camera mount
Could someone point me in the right direction?
I want to change this in my private fork only for the time.
