The direct drive tail rotor on my heli (an ebay 10Amp simonk ESC) requires me to move the
yaw stick full left after I plug the battery in so it can program itself. Once it is programmed,
it will be at full throttle spinning even if the yaw control stick on my transmitter is centered.
I have to put the stick left to stop the rotation. I didn’t see anywhere on the GUI to set the
control input range for the direct drive tail rotor, any suggestions would be appreciated, thanks!
Also in my other post I mentioned also a bug I think, where the direct drive tail rotor will be
spinning even when the helicopter is unarmed!
cheers,
Jamie
