When the differential-drive boat is set to auto mode and the waypoint is set, it starts spinning in place.Will setting the distance of the waypoint too short cause this situation.
To avoid guessing it might be good to present a log.bin file to show the behaviour. Also it might be good to decribe a little more your boat.
Does the boat drive correctly in Acro Mode?
if it doesnt drive properly in acro, most likely one of your motor is reversed
I will try it tomorrow, thanks
You can’t get past testing in Acro Mode if you followed the Tuning Turn Rate wiki. One of 3 steps that are really mandatory.
