Hello, I have a problem with my CRSF and MissionPlanner.
In betaflight everything works normal, but when I tried to do the RC Calibration I don’t see the green bars moving for the channels.
I tried quite a few different ways to fix it but it seems that nothing works, I would love for some help with this situation, thank you in advanced!
dkemxr
(Dave)
2
What F405 mini and how is the Rx connected?
The Diatone Mamba F405 mini
I added a proper descriptive title to your post.
dkemxr
(Dave)
5
I asked 2 questions and you gave one answer. So, here are the resources you need to troubleshoot the problem:
Mamba F405
CRSF and ELRS RC Systems
Already tries using these two sources, still didn’t work
And I tried wiring the Rx to both UART1 and UART2, both of them didn’t work
Allister
(Allister Schreiber)
8
Stay on Serial1.
Make sure the receiver’s TX wire goes to RX1, and receiver’s RX wire goes to TX1.
Set the params:
SERIAL1_PROTOCOL,23
SERIAL1_OPTIONS,0 #probably is already.
Make sure you power off everything and then power it up again to test it. Any changes to serial ports require a power cycle to take effect.
dkemxr
(Dave)
9
What @Allister said and make sure you do not have protocol 23 for more than one serial port.
Already did that and it didn’t worked, and I did made sure as well that only serial1 was on RCIN (23)
dkemxr
(Dave)
11
After connection to Mission Planner capture the messages screen under the HUD and post a screen shot. And attach the parameter file.
