hello,
my vtx is always turn off,because i dont know how power on vtx power switch with orducopter…
(it is work well whit inav ,but i prefere arducorter :-)))
thank you very much
Did you read the Wiki?
Vtx control
Thanks, I read the vtx wiki. But it’s a flight controller problèm. I dont know how powered the vtx with mamba f405 mini mk4.
I messed up on the H743 with VTX power so I could have made the same mistake on the F405 mini. Which target are you flashing? is it the 2022B?
Yes, I screwed up. Fix is here: Mamba F405 2022 VTX Power by andyp1per · Pull Request #22976 · ArduPilot/ardupilot · GitHub
Can you try this firmware?
arducopter.zip (646.0 KB)
Thanks very much.
I try this on the mamba f405miny 2022_typeB
If you can let me know today that would be great as I can get it on the dev call this evening. You might have to set RELAY_DEFAULT = 1 to get it to work (or at least if this is set to 0 after the upgrade set it to 1)
Thanks…
No problèms, I try after 8pm utc.
hello its OK
RELAY_DEFAULT=1
RELAY_PIN2=81
the vtx is powered whit a switch
thant you
Excellent, thanks for the report!
