Dev Call Sept 7, 2026
CI workflows
Release Update
Issues & Pull Requests
Attendee count (max): 12
UTC2300 - CI https://github.com/ArduPilot/ardupilot/actions/workflows/ci.yml
  • Pierre has trimmed down the lists
  • Pierrre got us a bunch of parallel runners (40 rather than 20)
  • We’ll probably move to just using debug symbols on CI rather than debug
UTC2310 - release update
  • 4.7.2 beta1 soon?
  • PR has been raised
    • Not on call
  • Sub guys want the multiple-udp-packet-enhancement
  • Why new boards not in stable?
    • Mostly just not marked for backport
  • 4.7 issue list getting a little out of control
  • CRSF regression
  • Heargrave ESC issue
    • Possible problem in ArduPilot
    • <4 dshot ESCs errors appear which aren’t real?
  • How many issues with dshot have we seen!?
    • “Fundamentally a hack”
    • Very pragmatic….
    • Bidirectional telemetry/fast rates on a single wire which used to carry pwm
    • Randy wants DroneCAN!
  • We did get the QMC5883P in by default now, resolving one
UTC2312 - AP_InertialSensor: support fast rate primary on MPU6000 by andyp1per · Pull Request #27893 · ArduPilot/ardupilot · GitHub
  • Support fast rate primary on MPU6000
  • Small blast radius
  • Merged!
UTC2324 - AP_Scripting: revert the reduction of MAXVARS and MAXUPVAL by timtuxworth · Pull Request #30731 · ArduPilot/ardupilot · GitHub
  • AP_Scripting: increase lua MAXVARS
  • Tim keeps running out of local variables
  • We reduced these years ago but it was probably ineffective
  • So here we restore to stock values
  • Just reverts
  • Merged!
UTC2326 - AP_NavEKF3: inhibit Z gyro bias from optical flow with no yaw reference by andyp1per · Pull Request #33498 · ArduPilot/ardupilot · GitHub
  • AP_NavEKF3: inhibit Z gyro bias from optical flow with no yaw reference
  • Randy has concerns on how stale the data is
UTC2330 - Plane: Quadplane: enable weathervane in VTOL auto by IamPete1 · Pull Request #33836 · ArduPilot/ardupilot · GitHub
  • Enable weathervane in VTOL auto
  • Would be nice to have a common function for gating weathervaning
    • But good enough
  • Merged!
UTC2347 - Plane: Quadplane: add a loiter stage in VTOL land approach with a loiter time of `Q_RTL_PAUSE_TIME` by IamPete1 · Pull Request #33842 · ArduPilot/ardupilot · GitHub
  • Add a loiter stage in VTOL land approach
  • At the top of a descent it will hang out before starting a descent
    • RTL or VTOL landing
  • Defaults to zero
    • Unless you’re a tilty tailsitter in which case it defaults to 5 seconds
  • Merged!
UTC2357 - Tradheli: improve swashplate collective and cyclic pitch logging by bnsgeyer · Pull Request #34153 · ArduPilot/ardupilot · GitHub
  • Improve swashplate logging
  • Why not remember what you shoved into the mixer in the first place?
    • Achieved versus desired
  • Few little things to fix up
UTC0010 - Optimize uint64_div1000() on 64-bit by rsaxvc · Pull Request #34164 · ArduPilot/ardupilot · GitHub
  • Optimise uint64_div1000
  • Twice as fast
  • Tridge is a little uncomfortable, review left
UTC0020 - autotest: pace CommonOriginExternalAHRSReceives's prearm polling by peterbarker · Pull Request #34171 · ArduPilot/ardupilot · GitHub
  • Pace sending of prearm command to the SITL binary in an autotest
  • merged
UTC0020 - QuadPlane: fix units mixup in the back pitch limit filter by peterbarker · Pull Request #34177 · ArduPilot/ardupilot · GitHub
  • fix units mixup in the back pitch limit filter
  • Going to flight test it
  • But probably still remove it
UTC0028 - SITL fixed UDP/multicast sockets blocking by timtuxworth · Pull Request #34181 · ArduPilot/ardupilot · GitHub
  • Fix blocking mcast ports
  • Merged!
UTC0030 - Plane: QuadPlane backward airspeed limit to avoid reversed tail flow by Hwurzburg · Pull Request #34202 · ArduPilot/ardupilot · GitHub
  • Quadplane backward airspeed limit to avoid reversed tail flow
  • Conflicting and Henry needs to comment
UTC0033 - autotest: fly TestAutoSpeedFlaps' flap check at cruise, not full throttle by peterbarker · Pull Request #34228 · ArduPilot/ardupilot · GitHub
  • autotest: fly TestAutoSpeedFlaps’ flap check at cruise, not full throttle
  • Merged
UTC0033 - AP_Scripting: integrate the elapsed time in the GAT example by peterbarker · Pull Request #34249 · ArduPilot/ardupilot · GitHub
  • Corrects integration of position target in Lua script used in new (slightly flakey) autotest suite.
  • Merged!
UTC0035 - Use AP_Follow for mount/gimbal tracking if tracking a SYSID by timtuxworth · Pull Request #34237 · ArduPilot/ardupilot · GitHub
  • Use AP_Follow’s concept of where the target is for follow
  • Tim’s going to go back to the old version of this
UTC0048 - AP_Baro: read bmp581 thrice to get corrected data by peterbarker · Pull Request #34265 · ArduPilot/ardupilot · GitHub
  • Read baro bmp581 three times to avoid beat frequency issue
  • Merged!
UTC0052 - AP_Camera: improve MAVLink camera and gimbal integration by tridge · Pull Request #34276 · ArduPilot/ardupilot · GitHub
  • Improve mavlink camera and gimbal integration
  • Private link
    • We relay stuff
  • We were just casting a target frame which was bad
    • We’re not just passing an AMSL to the camera
  • Multiple cameras on the same mavlink link?!
    • Ignore the problem
  • Private links?
    • Video stream information twice
  • Republishing should go via the vehicle’s system id and component ID
UTC0031 - Plane: apply throttle limits to tiltrotor forward thrust by Hwurzburg · Pull Request #34277 · ArduPilot/ardupilot · GitHub
  • Plane: apply throttle limits to tiltrotor forward thrust
  • PH would like to apply the throttle limits earlier
    • So apply them on the way into the outputs rather than on the outputs later
  • PH doesn’t think we need to rush this one in
  • Worth fixing
    • Bypasses the slew rate
  • Logging is bad
  • Users don’t want their motors to burn out even when doing this tilting, so it is important
UTC0038 - AP_RCTelemetry: thread safety for CRSF by landswellsong · Pull Request #34307 · ArduPilot/ardupilot · GitHub
  • Move to next week
UTC0038 - Buzzs new zephyr hal by davidbuzz · Pull Request #34319 · ArduPilot/ardupilot · GitHub
  • Buzz’s new zephyr HAL
  • Huge PR
    • Tridge has it booted on a CubeOrange
    • 4000Hz attempt?!
  • Needs to be de-scoped
    • C6 / monocypher will be removed
UTC0106 - throttle limit redux
  • Henry’s trying to get someone to not run a custom version of ArduPilot
  • User’s vehicle shakes apart
  • Also pitch-down issue
  • Good reviews on mid-sized hobby crowd
  • There’s a crash log
  • Hard-coded PID values and @ReadOnly…
  • They’re running custom patch firmware
  • PH will look at the PR
UTC0113 - close
