Dev Call Sept 14, 2026
CI Workflows
Release Update
AI Review
Issues & pull Requests
Attendee count (max): 13
UTC2300 - CI https://github.com/ArduPilot/ardupilot/actions/workflows/ci.yml
  • Scattering of random things
    • Maybe new CPUs?
  • Randy is saying he’s having issues with the release
    • PB: Can’t just hit restart as it just kick the problem to the partners
    • PB: can probably point Randy to the right fixes
UTC2310 - release update
  • Co-ordinated turns love/hate?
    • Some users don’t love it!
    • This week was low speeds
    • Combined with high yaw rates
    • Should we parameterise the threshold over which we apply the co-ordination?
      • Probably
  • Log from user with over-powered copter
    • Jame throttle and he gets 5G and the barometer goes up
    • Ducted-fan copter
    • Andy’s barometer thrust scaling fixed the problem
    • if you see a log where the baro alt goes up don’t assume the vehicle is actually going up
      • Can see it on Plane with ram air
  • Blademaster had a crash
    • Tridge requested logs
  • The EKF multi-height stuff
    • CTUN only reports the normal climb rate
    • When vibe compensation is on we use a different value
  • Watchdog issue?
    • Tridge suggested the user try 4.8 to get a good crashdump
    • Wiping parameters seems to have fixed the problem
      • Want a copy of those parameters
  • Copter toilet-bowling?
    • Probably sensor issue / unhappy EKF
  • Heargrave D-Shot ESCs
  • Maybe we have a bug in our ESC logging
  • Two release PRs we need to get out the door
    • 4.7.2
    • 4.6.4
      • To fix the logging bug which on a misconfigured notch filter can cause an in-flight reset
UTC2320 - https://github.com/ArduPilot/ardupilot/pull/33717
  • CoreWingF405 board
  • Bad documentation
  • Merged anyway!
UTC2323 - https://github.com/ArduPilot/ardupilot/pull/34206
  • WASM SITL
    • in-the-web-browser
  • It’s quite small
  • The single-uart is the real drawback here
  • Some things to chase up in a review
UTC2346 - autotest: skip MAVFTPCrcCompareMAVProxy on a MAVProxy without crccmp by peterbarker · Pull Request #34105 · ArduPilot/ardupilot · GitHub
  • autotest: skip MAVFTPCrcCompareMAVProxy on a MAVProxy without crccmp
  • Merged!
UTC2347 - RC_Channel: defer aux initialization until backends exist by Hwurzburg · Pull Request #34166 · ArduPilot/ardupilot · GitHub
  • Defer aux init until backends exist
  • Henry changed the init order
  • Peter will look at this one
  • Now a test which fails before / after
UTC2352 - Add support for FTP ListDirectoryWithTime by peterbarker · Pull Request #34229 · ArduPilot/ardupilot · GitHub
  • Support list-directory with time
  • Need to make sure the allocation for the buffer only happens when you use the alias
  • Will bring this back
  • Consider alloca in rename
UTC0009 - Rover: Update limits at each waypoint by stephendade · Pull Request #34256 · ArduPilot/ardupilot · GitHub
  • Honour parameter changes when they are changed live
  • MergeOnCIPass!
UTC0011 - Plane: apply throttle limits to tiltrotor forward thrust by Hwurzburg · Pull Request #34277 · ArduPilot/ardupilot · GitHub
  • Limit throttle on forward-pitch motors
  • User has tested and confirmed it works
  • Needs PH to approve
  • PH was considered a rewrite
    • There’s a test which will make that nice
UTC0012 - AP_RCTelemetry: thread safety for CRSF by landswellsong · Pull Request #34307 · ArduPilot/ardupilot · GitHub
  • AP_RCTelemetry: thread safety for CRSF
  • Continues to retry to init object even when it fails
  • Can’t do this while armed
  • Can be merged once the armed thing is taken care of
UTC0019 - https://github.com/ArduPilot/ardupilot/pull/34319
  • Zephy support
  • Now fleis in renode
  • Can flash with the ArduPilot bootloader
    • Probably would work with the PX4 bootloader
    • MCUBoot?
      • Should be removed from the PR
      • Third ecosystem
        • Probably want support at some stage
    • Want users to use the ArduPilot bootloader
    • Apj is still not generated
  • Buzz to read through the patches
UTC0037 - Small airspeed-related changes by peterbarker · Pull Request #34326 · ArduPilot/ardupilot · GitHub
  • Small airspeed related changes
  • We’ll move tridge’s AIReview into a fresh repo in ArduPilot
  • He’ll add support for @AIReview
  • Merged!
UTC0041 - Tools: AP_Periph: init rangefinder without serial port by IamPete1 · Pull Request #34344 · ArduPilot/ardupilot · GitHub
  • Init rangefinder without serial port
  • Merged
UTC0045 - AP_HAL_ChibiOS: fix H730/H723 ADC kernel clock exceeding STM32_ADCCLK_MAX by Hwurzburg · Pull Request #34349 · ArduPilot/ardupilot · GitHub
  • AP_HAL_ChibiOS: fix H730/H723 ADC kernel clock exceeding STM32_ADCCLK_MAX
  • Chibios upgrade bug
  • Tridge is happy but Andy to re-review
UTC0049 - Plane: don't use output limit in fbwa glide failsafe by IamPete1 · Pull Request #34351 · ArduPilot/ardupilot · GitHub
  • Don’t use the output limit in fbwa glide failsafe
  • Comments left
  • Still a draft?!
UTC0056 - AP_NavEKF3: fix the sign of the SRTM height used for flow scaling by andyp1per · Pull Request #34360 · ArduPilot/ardupilot · GitHub
  • Fix ICM56686
  • Merged!
UTC0111 - AP_ADSB: bound Sagetech GPS message field widths by peterbarker · Pull Request #34370 · ArduPilot/ardupilot · GitHub
  • AP_ADSB: bound Sagetech GPS message field widths - #34370
  • Abstracts out a format latitude/format longitude for common usage
  • Merged!
UTC0112 - AC_Avoid: do not back away from the optical flow height limit by andyp1per · Pull Request #34380 · ArduPilot/ardupilot · GitHub
  • Do not back away from optical flow height limit
  • Drive off a cliff and it forces the vehicle down
  • Randy is going to test it
UTC0122 - AP_AHRS: populate ExternalAHRS results even when attitude is invalid by peterbarker · Pull Request #34382 · ArduPilot/ardupilot · GitHub
  • Fill in all AHRS results even if we don’t have an attitude
  • If the AI is fine with the always-assign then we can merge it
UTC0130 - AC_PrecLand: suppress QURT float absolute-value (fabsf) warning by katzfey · Pull Request #34406 · ArduPilot/ardupilot · GitHub
  • AC_PrecLand: suppress QURT float absolute-value (fabsf) warning - #34406
  • Merged!
UC0131 - close
