CraigElder
(Craig Elder)
1
Issues & Pull Requests
Plane
Copter
Rover
CraigElder
(Craig Elder)
2
Attendee count (max): 18
UTC1100 - https://github.com/ArduPilot/ardupilot/issues/15341
- Bad yaw estimate
- Copter / tailsitter Plane
- Bad yaw estimate on EKF3
- EKF2 is OK
- Previous test-branch worked OK
- So something has broken recently
- Broke about 2 week ago
- Log shows massive innovations on mag
- Earth-field estimates are close, âthough
- Tridge will look at this off-line with PH
UTC1108 - https://github.com/ArduPilot/ardupilot/issues/15326
- Remove arming check all option
- (bit 0 / value 1)
- Arming force is supposed to replace unsetting the bits
- But sometimes you need to disable e.g. compass on a permanent basis
- Maybe another mask - âarm check offâ?
- Use the highest value possible to set the maximum transportable bits
- Tridge and Peter both like the âinvertedâ âinhibit checkâ concept
UTC1115 - https://github.com/ArduPilot/ardupilot_wiki/issues/1975
- Old issue thatâs been overtaken by patches
- Issue was actually fixed some time ago
- Closed
UTC1115 - https://github.com/ArduPilot/ardupilot/pull/15338
- Merged
- Travis display improvement
UTC1118 - https://github.com/ArduPilot/ardupilot/issues/15322
UTC1120 - https://github.com/ArduPilot/ardupilot/pull/15318
- Probably want to do a bit of refactoring around this area
- Move it into AP_Vehicle
- Remove printfs directly
- Send-text in ap-vehicle then this can be merged
UTC1125 - https://github.com/ArduPilot/ardupilot/pull/15316
UTC1126 - https://github.com/ArduPilot/ardupilot/pull/15297
- Blasting all of the values isnât great as some of them are carefully crafted
- Too broad a change
- Thought needs to be put into each individual change
UTC1131 - https://github.com/ArduPilot/ardupilot/pull/15272
- If a goto command is rejected then the vehicle keeps doing what itâs doing
- Could instead fly to point at edge of fence?
- Merged!
- Related
- Add more checks around Missions to make sure theyâre sane
UTC1136 - https://github.com/ArduPilot/ardupilot/pull/15263
- Lock in versions of gcc which donât produce any warnings on stm32 builds
- Two whitelisted compilers ATM
- 4.9.3 and 6.3.1
- Only applies to C++ code
- C code produces some warnings
- Whitelisting in SITL might come along
- Merging this might break master
- Depends on whatâs been merged today
UTC1141 - https://github.com/ArduPilot/ardupilot/pull/15081
- Really expensive message
- Worried about bandwidth
- Can decimate onboard producers
- Parameter AVD_OPTIONS to enable the message?
- Maybe a way to decide which message to use?
- Choose between rangefinder distance and obstacle distance depending on bandwidth?
UTC1155 - https://github.com/ArduPilot/ardupilot/pull/14984
- Randy needs to review this
UTC1156 - https://github.com/ArduPilot/ardupilot/pull/13885
- Definitely need to avoid using existing logging system for logging EKF inputs
- Merged
UTC0002 - https://github.com/ArduPilot/ardupilot/pull/13853
- Correct change
- Real issue
- Hasnât checked the implementation
- Michael wants ot check with uCenter
- Canât allocate lots and lots of channels to Galileo
- Wouldnât allocate any so wouldnât track Galileo
- MdB will merge when ready
- Having trouble finding time
- Tridge might also find time to test
UTC0004 - https://github.com/ArduPilot/ardupilot/pull/13804
- Revisiting an old one
- Bounce to Andy?
- Power_watts could be incorrect in some cases
- Should we have a batt-index instead of a sum?
- Getting rid of places which nominate 0 or use the default battery number
- Places will need to nominate their battery
- OSD_BATT_IDX
UTC0014 - https://github.com/ArduPilot/ardupilot/issues/14460
- 4.0.6 is out
- Will be a 4.0.7
- Compass failover problem
- Currently active compass dies completely (e.g. canbus cable comes loose)
- EKF will not fail over to second compass
- Works in master
- Worked in early 3.6 Copter releases
- Broken for a long time
- There is some observability of yaw when moving along in a Copter
- No nasty reports from 4.0.6
- 4.1 beta period within next month
- Airspeed affinity was flown on the weekend
- Worked as designed
- Dual-airspeed is a real win as failed airspeed sensors has been a Plane-killer
UTC0018 - https://github.com/ArduPilot/ardupilot/issues/12547
- For 4.1
- Randy would like to get EKF sensor source stuff
- S-curve navigation
- Back on top of Randyâs list
- Another week before a PR comes in
- A solid month and Copter might be ready
- Still no Copter stable release
- MP prioritisation table problem
- Hopefully MO will get to this today
UTC0023 - Rover?
- Zero-turn-mower
- Two F9s for yaw
- Struggle to set up the GPSs
- Need to look at why he struggled so much
UTC0024 - User Alerts
- Just about ready to roll!
- Documented on Wiki
- ArduPilot repo is up and running
- Do we want to put issues prior to now into the database?
- Disadvantages
- Advantages
- Quick win for those using older firmwares
- Candidates
- CubeOrange parameter resets
- IMU lockup problem when hardware goes away (the one that made us do watchdog etc)
- Will let us test the process of adding user alerts as well
- Tridge will work with Stephen to get an entry in
- MAVProxy already has an implementation
- MP is getting patches
- Blog post coming explaining what the DB is and how weâre using it
UTC0034 - https://github.com/ArduPilot/ardupilot/pull/15146/files#
- Need a junkcode test to make sure subtracting a pair of uint16_tâs does the right thing
UTC0042 - vibration compensation?
- Heuristics are relatively easy to find
- Need a tlog
UTC0045 - Mower log
- Very nice yaw from the GSF!
- Mowers + GSF might be a thing!
- Primary GPS keeps dropping offline
UTC0052 - Closed
