Dev Call Oct 5, 2026
CI workflows
Release Update
AI Review
Issues & Pull Requests
Attendee count (max): 16
UTC2301 - CI https://github.com/ArduPilot/ardupilot/actions/workflows/ci.yml
UTC2306 - vehicle update
  • ArduPilot 4.7 issues list · Issue #32385 · ArduPilot/ardupilot · GitHub
  • 30 or so patches in the current beta
  • Not a huge amount of feedback on it
    • Rolf said it was OK
  • Couple of scary issues did come up
    • Fix for Vibration compensation failsafe response merged
    • Poshold brake entry issue
      • 10x too large
    • tridge thinks the interrupt storm should come back
      • Only seen on bench, but theoretically it could happen when flying
    • Fastrate pid values pidr/pidp massive spikes in the output
      • Real bug
      • Only happens if fastrates are enabled
      • Twitches
      • Fix is around
  • 4.7.2 ZeroOne rotation issue is still something we are curious about and will test
  • QRTL issue in Plane
    • Maybe expected - PH will chase
    • Something that Henry fixed recently
UTC2316 - AP_VideoTX: user-definable VTX band table (builds on #34379) by j-w9 · Pull Request #34520 · ArduPilot/ardupilot · GitHub
  • User-definable VTX band
  • Shoving stuff into mission storage is an interesting decision
  • Why not ordinary parameters?
  • Henry thinks we shouldn’t be spending flash or mission storage on this
  • Doesn’t currently work on F405
    • But should
  • They’re going to see if they can use parameters rather than an entire virtual filesystem to upload the data
UTC2337 - SRV_Channel: Betaflight-style per-output servo failsafe positions by j-w9 · Pull Request #34109 · ArduPilot/ardupilot · GitHub
  • Servos to betaflight positions
  • RC scaled passthrough to failsafe position
    • To turn a light on when RC goes out
    • RC passthrough angle vs range
  • RC-passthrough as angle-vs-range based maybe?
  • Tridge suspects a single-bit would do it
    • Peter thinks another enumeration value for use-range-scaling
    • [10:47 AM]Peter Hall: I would vote to add them to the enum, more scaled outputs.
UTC2352 - Copter: fix compassmot so that it works with the rate thread by andyp1per · Pull Request #30980 · ArduPilot/ardupilot · GitHub
  • Fix compassmot to work with rate thread
  • Merged
UTC2354 - AEDROXH7 FC - Update by Aedrox-UAx · Pull Request #33393 · ArduPilot/ardupilot · GitHub
  • Aedrox H7 board updates
  • Merged!
UTC2354 - AUTO cleanup by lthall · Pull Request #33834 · ArduPilot/ardupilot · GitHub
  • AUTO cleanup
  • Same treatment as RTL got, renames and the like
  • Merged!
UTC2359 - Scripted Bendy Ruler based Object Avoidance for Plane by timtuxworth · Pull Request #33955 · ArduPilot/ardupilot · GitHub
  • Plane bendy-ruler support
  • –enable-oa-scripting
  • Would be nice to get this to zero-bytes output change
  • Will be back with this
UTC0012 - AP_Logger: let the block backend use the configured buffer size by peterbarker · Pull Request #34172 · ArduPilot/ardupilot · GitHub
  • Make use of parameter in the log-bufsize code
  • Merged!
UTC0014 - Copter: interpolate the rate target in the fast rate thread by andyp1per · Pull Request #34208 · ArduPilot/ardupilot · GitHub
  • Copter: interpolate the rate target in the fast rate thread
  • Using std::atomic now?!
  • Review comments left
UTC0023 - Replay: Avoid over-reading from log files when message length changes by peterbarker · Pull Request #34491 · ArduPilot/ardupilot · GitHub
  • Avoid over-reading from log files when message length changes
  • Merged!
UTC0024 - GCS_MAVLink: bound the FTP wait for room on the link by peterbarker · Pull Request #34537 · ArduPilot/ardupilot · GitHub
  • Avoid losing sessions due to lost channel mask and an infinite loop
  • AI has found yet another issue
    • Trivial ‘though
UTC0026 - AP_RCProtocol: warn of CRSF UART without RX DMA by Hwurzburg · Pull Request #34559 · ArduPilot/ardupilot · GitHub
  • Warn when crsf unlikely to work well
  • MergeOnCIPass
UTC0028 - Correct Replay when setting origin via MAVLink by peterbarker · Pull Request #34562 · ArduPilot/ardupilot · GitHub
  • Correct Replay for origin-set-from-GCS case
  • MergeOnCIPass
UTC0029 - AC_AttitudeControl: fix throttle-gain boost and throttle mix with the fast rate thread by andyp1per · Pull Request #34583 · ArduPilot/ardupilot · GitHub
  • fix throttle-gain boost and throttle mix with the fast rate thread
  • Needs Leonard to be happy
  • AI review needed
UTC0031 - AP_OSD: confine DisplayPort writes to canvas by Hwurzburg · Pull Request #34589 · ArduPilot/ardupilot · GitHub
  • Constrain displayport osd parameter offsets to be correct
  • Caused display to disappear
  • Merged!
UTC0035 - AP_Arming: report RC option conflicts as periodic pre-arm failures by Hwurzburg · Pull Request #34592 · ArduPilot/ardupilot · GitHub
  • AP_Arming: report RC option conflicts as periodic pre-arm failures
  • Need to take out the Check::Parameter thing
  • Can be merged after that
UTC0041 - Fix interrupt storm lockup in BLHeli passthrough and get crash dumps for interrupt starvation by tridge · Pull Request #34597 · ArduPilot/ardupilot · GitHub
  • Fix interrupt storm lockup in BLHeli passthrough and get crash dumps for interrupt starvation
  • Affects any situation where we are twiddling GPIOs (set or toggle)
  • Another pin on the same pad can modify the pin state between to operations
  • Blheli passthrough will be much more reliable after this goes through
  • Peter’s happy enough but another round for people to comment on!
UTC0106 - AP_InertialSensor: log every filtered gyro sample with the rate thread by andyp1per · Pull Request #34601 · ArduPilot/ardupilot · GitHub
  • AP_InertialSensor: log every filtered gyro sample with the rate thread
  • Seems to fix a problem where data may be being changed as it is being logged?!
  • AIReview required
UTC0111 - AP_HAL_ChibiOS: enable H7 SRAM before the first stack access by tridge · Pull Request #34604 · ArduPilot/ardupilot · GitHub
  • Turn on the memory used for stack early in boot so we don’t need ALT_RAM_MAP
  • Tridge wants to use the RAM map used by CubeOrangePlus
  • Tridge wants to talk with Thomas on this one
UTC0014 - AP_Param: wait for in-flight saves in flush by tridge · Pull Request #34618 · ArduPilot/ardupilot · GitHub
  • Correct chained parameter upgrades
  • Needed to take a mutex
  • We’re thinking of doing the whole std::atomic for this sort of thing….
UTC0018 - AP_RCProtocol, AP_HAL_ChibiOS, RC_Channel: Support 24 RC channels by olliw42 · Pull Request #34615 · ArduPilot/ardupilot · GitHub
  • Support 24 channels in RCProtocol
  • General agreement that we can go to 32 channels
  • Reviews left
UTC0032 - Copter: Circle: allow pilot to reduce radius to zero by Hwurzburg · Pull Request #34621 · ArduPilot/ardupilot · GitHub
  • Allow radius to go to zero
  • Merged!
UTC0034 - WIP: enable LTO for ChibiOS builds by tridge · Pull Request #34622 · ArduPilot/ardupilot · GitHub
  • Build LTO
  • For discussion with Thomas
  • Long-term project
UTC0034 - ChibiOS: Fixed stack overflow in crashdump setup by tridge · Pull Request #34626 · ArduPilot/ardupilot · GitHub
  • New Python tool that analyses entire call chain
  • Fix stack overflow on exception
  • Fix race condition AP_Vehicle
  • Merged!
UTC0036 - hwdef: variant of TBS_LUCID_H7_WING uses MPU6000 by andyp1per · Pull Request #34629 · ArduPilot/ardupilot · GitHub
  • Correct IMUs on TBS board
  • Merged!
UTC0039 - close
