Dev Call Oct 26, 2020
Issues & Pull Requests
Plane
Copter
Rover
Attendee count (max): 17
UTC1100 - Copter update
  • twitching pitch works on 4.0.4
    • So not a blocker for 4.0.5 any more!
    • 4.0.5 will be out today or tomorrow
UTC1102 - Plane update
  • Tridge looking at Nate’s log
UTC1103 - https://github.com/ArduPilot/ardupilot/pull/15314
  • Bi-directional telemetry logs
  • This has been a very long time coming
    • Should we hold this up?
  • Wire Protocol isn’t as good as it could be
  • Use mavftp?
    • No memory on the transmitter side!
  • Community probably won’t mind too much if we change the protocol later
  • Flash cost?
    • Why do we have so much flash free at the moment?
  • https://autotest.ardupilot.org/build_binaries_history.sqlite
UTC1118 - https://github.com/ArduPilot/ardupilot/pull/15194
  • Show frame type as text via mavlink
  • Have a const-char-* on the motors backend
  • Randy will push this one along
UTC1123 - https://github.com/ArduPilot/ardupilot/pull/15021
  • Adds missing betaflight frame reversed
  • merged!
UTC1123 - https://github.com/ArduPilot/ardupilot/pull/15653
  • Enables proper OOP type stuff
  • Uses a lot less memory than e.g. tridge’s PID example
  • MdB will try to get an example together for using this
UTC1125 - https://github.com/ArduPilot/ardupilot/pull/15650
  • Fport2 support
  • And cleanups so the flash cost is minimal
  • Completely different protocol to fport1, near-enough
  • Test-suite for fport and fport2 added
  • Should run the rc protocol tester as part of CI
  • Fport and fport2 are inverted 115200
  • Peter will merge after the call after looking at it
UTC1127 - https://github.com/ArduPilot/ardupilot/pull/15642
  • Fix css on ardupilot.org
  • What testing has been done?
  • Needs to be run on the autotest server via ssh
UTC1135 - looking at flash
  • MO looked at DB and found a big gap
  • Need to look at why the big drop…
UTC1137 - https://github.com/ArduPilot/ardupilot/pull/15639
  • Race-condition causing watchdogs
    • Probably only on ground
  • Stop two threads doing filesystem operations at the same time
  • All filesystems operation must go via AP_FileSystem and this enforces that
UTC1145 - fix build on 9.3
  • Merged!
UTC1146 - https://github.com/ArduPilot/ardupilot/pull/15627
  • Needs review comments to be looked at
UTC1146 - https://github.com/ArduPilot/ardupilot/pull/15575
  • Add midposition option
  • Merged!
UTC1148 - https://github.com/ArduPilot/ardupilot/pull/13856
  • Merged!
UTC1148 - https://github.com/ArduPilot/ardupilot/pull/15620
  • Log banner
  • How does this actually help?
  • Does the obfuscation actually help?
  • Randy doesn’t think it adds value or will dissuade people
  • Inflicting this on all users
  • Only to dataflash logs…
  • No appetite for this
  • We do NOT want people running AP on manned stuff, but this isn’t really going to help
  • Craig reached out to the EAA article author to point out our policy and they might print a retraction of some description
UTC1151 - https://github.com/ArduPilot/ardupilot/pull/15621
  • AP_Scripting add parameterto disallow scripts from places
    • E.g. don’t load from ROMFS
    • Defaulting to not running scripts on SITL on Linux
    • Tridge likes scripts on ROMFS on Linux
      • So change default to retain current behaviour
  • Tridge had a patch to have scripts on SD card override scripts in ROMFS
    • ROMFS forces the script to run
UTC0003 - https://github.com/ArduPilot/ardupilot/pull/15567
  • Fix issue previously added with tailsitters
  • Merged
UTC0005 - https://github.com/ArduPilot/ardupilot/pull/15520
  • First conservative GPS_AUTO_SWITCH
  • Behaviour change…
  • Primary == 5 will force to zero
  • Should be able to fly with only a second GPS
  • Blended as primary?
  • Naming issue?
  • Choosing what to switch to can be problematic
    • E.g. F9 not using SBAS only etting lock-type-3 and M8 giving type 4
    • E.g. RTK?
    • More work will be done on this
UTC0017 - https://github.com/ArduPilot/ardupilot/pull/15498
  • AP_Airspeed: add dedicated wind max param
  • Better logic around GPS going away added since last time
    • you will get your airspeed sensor back
  • WIND_WARN and WIND_MAX
  • Parameters are global
UTC0021 - https://github.com/ArduPilot/ardupilot/pull/14852
  • Add support for NMEA water sample
  • Adds matlab nmea water speed sensor
  • AP_Airspeed/ models
  • How does this work on negative waterspeeds?
  • Doesn’t fuse this into the EKF at this point
    • Logged only
UTC0024 - https://github.com/ArduPilot/mavlink/pull/153
  • Merged!
UTC0028 - closed
