Issues & Pull Requests
Plane
Copter
Rover
Plane
Copter
Rover
Attendee count (max): 22
UTC1100 - https://github.com/ArduPilot/ardupilot/pull/15520
UTC1120 - https://github.com/ArduPilot/ardupilot/pull/15498
Wind_max disables sensor
Wind_warn warns about high wind
Disabling airspeed sensor by setting wind_max
No stable release with AIRSPEED_OPTIONS?
Disable on sensor failure?
Gps speed accuracy?!
Airspeed used to keep attitude in DCM….
Quote of the day: “Since you are going to be re-writing this code to be neater you might as well rewrite it so it works”
Probability failure work correctly 10m/s vs 100m/s?
We do need to think about where we use gps-based things in the code as vision is a thing now-adays
UTC1135 - https://github.com/ArduPilot/ardupilot/pull/15493
UTC1136 - https://github.com/ArduPilot/ardupilot/pull/15234
UTC1148 - https://github.com/ArduPilot/ardupilot/pull/14852
UTC1153 - https://github.com/ArduPilot/ardupilot/pull/15602
UTC0013 - https://github.com/ArduPilot/ardupilot/pull/15600
UTC0020 - https://github.com/ArduPilot/ardupilot/pull/15594
UTC0024 - https://github.com/ArduPilot/ardupilot/pull/15586
UTC0033 - https://github.com/ArduPilot/ardupilot/pull/15591
UTC0040 - https://github.com/ArduPilot/ardupilot/pull/15585
UTC0041 - https://github.com/ArduPilot/ardupilot/pull/15351
UTC0042 - https://github.com/ArduPilot/ardupilot/pull/15584
UTC0052 - https://github.com/ArduPilot/ardupilot/pull/15582
UTC0104 - https://github.com/ArduPilot/ardupilot/pull/15541
UTC0107 - https://github.com/ArduPilot/ardupilot/pull/15571
UTC0124 - https://github.com/ArduPilot/ardupilot/pull/15607
UTC0132 - Plane updates
UTC0135 - Copter and Rover updates
UTC0139 - out of time - closed
