Agenda: None - winging it.
Attendee count (max): 12
Many, many normal attendees at the Hex China conference so small turnout and missing our usual meeting chair, Craig.
UTC2300 - merge party!
- an hour spent merging random PRs into ArduPilot and pymavlink , mostly Peter’s
UTC0001 - MAVExplorer and MAVProxy updates
- Python3 support
- Works on MacOSX
- Should work on Windows
UTC0002 - AP_Avoidance
- Much plane-specific stuff at the moment
- Needs to be made general for the other vehicles
- Will require GPS
- Copter ought to be able to use same movement stuff as Plane
- Currently it moves the waypoint the vehicle is heading towards
- Relies on underlying navigation code
- L1 controller works things out nicely
- Position controller on Copter may not cope nicely
- Will probably go in in current form
- Maybe a good time to put the L1 controller in Copter
- This is long-distance avoidance
- Macro avoidance
- Hundreds of metres to kilometres
- Comes with the exclusion zones stuff
- Makes mission planning much, much easier
- Comes with fence avoidance for Plane
- As opposed to fence breakage and return
- Do the more deliberate vehicle avoidance stuff
- Tridge will be factoring this into a form to come into master
- With these changes we can have QGC do fences again!
- Will add a command-long to make it mavlink compatible
UTC0005 - low-hanging PR fruit in mavproxy
- Again, testing appreciated with tridge’s changes
- We now autobuild MAVProxy for Windows now using appveyor
- https://ci.appveyor.com/project/tridge/mavproxy/build/artifacts
- Use AP_ROMFS in SITL to store config files
- To make simulation easier on Windows
- MP does things slightly different in terms of defaults
- Slightly different behaviour
- So ROMFS on Linux and oming
- SITL already uses ROMFS for OSD
- Default set of scripts?
- No incremental decompression at the moment
- Really large scripts would need to be slurped in their entirety
- Needs 40kB to flash the IO firmware at the moment
UTC0019 - replacement IO firmware
- Close
- Running
- Io channels work
- One-shot works
- Brushed-motors work
- Not working:
- Analogue inputs
- Vservo
- Rssi analog input
- Mixer stuff
- Currently doesn’t work with ChibiOS fmu builds anyway with current firmware
- Analogue inputs
UTC0024 - MAVProxy PRs
- Merged some PRs nominated by Amilcar
https://github.com/ArduPilot/MAVProxy/pull/504/files
- Python3?
https://github.com/ArduPilot/MAVProxy/pull/490/files
- Use keyword “add” instead?
- Merged!
UTC0031 - another Plane issue assigned to tridge
