Dev Call Oct 13,2025
**CI Workflow review
Release Update
Issues & Pull requests
Attendee count (max): 15
UTC1101 - CI
UTC1105 - 4.6.3
  • More stuff was added yesterday for Plane
  • Ruben’s rangefinder fix could go into the next beta….
  • 4.6 Plane we had a critical failure / deadlock detection
    • AP: CRITICAL Deadlock 814 FTP 0x3000AE6C
  • Beta1 probably out in the next couple of days
UTC1120 - Rover: reject destinations outside fence in GUIDED mode by tridge · Pull Request #31003 · ArduPilot/ardupilot · GitHub
  • Make compass instance numbers common AP_Compass_backend
  • MergeOnCIPass
UTC1124 - AP_HAL_ChibiOS: fix bouncebuffer read cache logic by tpwrules · Pull Request #31244 · ArduPilot/ardupilot · GitHub
  • Fix bouncebuffer read cache logic
  • Tridge is considering whether this needs to go back into 4.6.2
    • Not for the next release, at least
UTC1129 - AP_Scripting: regenerate MAVLink message definitions by IamPete1 · Pull Request #31268 · ArduPilot/ardupilot · GitHub
  • We were accepting bad checksums for mavlink messages
    • Randy was getting corruption on telemetry link…
  • This was a “feature”!
    • CRC turned off so scripts can accept anything
    • Letting things through that were wrong
  • Merged!
UTC1134 - AP_GPS: only send GPS raw if GPS is enabled by IamPete1 · Pull Request #31273 · ArduPilot/ardupilot · GitHub
  • Only send GPS_RAW_INT if GPS is disabled
  • Merged!
UTC1137 - Fix use of body_to_earth2D and body_to_earth2D_p by lthall · Pull Request #31275 · ArduPilot/ardupilot · GitHub
  • Fix use of body-to-earth2d
  • MergeOnCIPass
UTC1143 - autotest: add more success cases to AUTOTUNE test by tpwrules · Pull Request #31278 · ArduPilot/ardupilot · GitHub
  • Add more buckets to the autotune test for Plane
  • Autotune doesn’t get the same result all the time
    • Add more buckets
  • Merged!
UTC1145 - off the floor
  • New Java-based GCS!
  • Blog post
  • Renamed OMC to discussions of new ground control stations
UTC0001 - off the floor
UTC0012 - payload release stuff?
  • Payload n vehicle and want to delay arming?
  • No, more “you’re taking too many pictures and need to slow down, or need to come back and take other pictures sort of thing
UTC0018 - close
