Dev Call Oct 12, 2026
CI Workflows
Release Update
AI review
Issues & Pull requests
Attendee count (max): 13
UTC2300 - pre-agenda
  • Tridge discusses Rust in ArduPilot
  • [10:08 AM]Peter Barker: BTW, I suggest “Rust modules” rather than “Rust scripts”
UTC2301 - CI Workflow runs · ArduPilot/ardupilot · GitHub
  • Peter made the AUTOTUNE stuff a little flakier with the rebalance of the buckets
  • What CI permissions are required for the WebTools?
    • Copied settings from other repo
UTC2308 - Release update
  • 4.7.2 will be coming out sometime tomorrow
  • 4.7.3beta1 will come out soon after that
    • Some important fixes
      • Vibe failsafe
      • Crashomatic unlikely
  • 4.6.4 soon after per-motor harmonic notch logging
    • Requires a misconfiguration to trigger so not absolutely urgent
  • Copter auto-flies into ground when spline followed by nav-delay
    • There’s an autotest to reproduce the bug
  • Optical Flow and GPS on the vehicle?
    • Using sensor-selection source sets
      • If you fly wthn rel-aiding and you then limit to 70% of range
      • Into GPS and then back into OF then you remain in absolute aiding and then you can break the ceiling
      • Stays in absolute aiding indefinitely
  • Crash report for Plane
    • Waiting on logs, but probably hardware
    • Spinning vehicle
  • Long-standing bug / forum post
    • QRTL doesn’t honour rtl-alt -1
      • -1 should be “Return at current altitude”
      • But -1 doesn’t work for QRTL….
  • We might want to backport 34714
    • GPS-based yaw alignment issue with bad GPS data
UTC2318 - hwdef: ZeroOneX6: fix SERIAL5 default protocol never being applied by Hwurzburg · Pull Request #34423 · ArduPilot/ardupilot · GitHub
  • Fix ZeroOneX6 serial default protocols
  • Merged!
UTC2319 - AP_AHRS: rename configured-backend accessors to reflect their scope by peterbarker · Pull Request #34566 · ArduPilot/ardupilot · GitHub
  • Rename accessors to point out they are for the configured backend
  • Merged!
UTC2322 - Have each AHRS backend handle its own airspeed_EAS and airspeed_TAS numbers by peterbarker · Pull Request #34574 · ArduPilot/ardupilot · GitHub
  • Have each AHRS backend handle its own airspeed
  • Can be merged after CI passes
UTC2333 - Preserve zero-initialised allocations and verify allocator wrapping by tridge · Pull Request #34657 · ArduPilot/ardupilot · GitHub
  • Preserve zero-initialised allocations and verify allocator wrapping
  • We weren’t zeroing memory on MacOSX
  • Gcc-16 wasn’t zeroing correctly
  • Thomas is concerned about the false-sense-of-security
  • Might get away from using newlib
    • Tridge has been shocked about how bad it is
    • E.g. rand() can call abort()!
UTC2340 - Remove use of HAL_BUILD_AP_PERIPH where it's not required by peterbarker · Pull Request #34658 · ArduPilot/ardupilot · GitHub
  • Remove more uses of HAL_BUILD_AP_PERIPH
  • Merged!
UTC2341 - Remove PX4_BOARD_FMUV6 from use by peterbarker · Pull Request #34669 · ArduPilot/ardupilot · GitHub
  • Remove PX4_BOARD_FMUV6
  • Old way of doing things!
  • Merged!
UTC2342 - Add support for camera survey modes by tridge · Pull Request #34688 · ArduPilot/ardupilot · GitHub
  • Add support for camera survey modes
  • Needs to point itself to do its survey
  • Whose responsibility to stop other mount commands coming through?
  • Should the flight controller stop controlling the gimbal?
    • This isn’t modifying send_target_to_gimbal?
UTC2354 - ChibiOS: remove newlib paths to abort() by tridge · Pull Request #34691 · ArduPilot/ardupilot · GitHub
  • Remove newlib paths to abort()
  • Should we be copy/pasting existing implementations rather than writing our own?
    • Our own strod
    • Our own rand()
    • abort() is now not permitted in flight code
    • Tridge used glibc as the Oracle rather than newlib
    • Both PH and tpw are skeptical of having our own
  • Tridge will work out when it calls abort() in the current code so we know
UTC0025 - Move the HAL_OS_*_IO defaults into AP_Filesystem_config.h by peterbarker · Pull Request #34694 · ArduPilot/ardupilot · GitHub
  • Move around some more defines
  • To make building faster in the future
UTC0026 - AP_Scripting: avoid recursive CAN buffer traversal by tridge · Pull Request #34704 · ArduPilot/ardupilot · GitHub
  • Fix stack overflow to do with CAN and Lua scripting
  • Merged!
UTC0030 - RC_Channel: remove pre-4.2 aux function entries from RCx_OPTION docs by Hwurzburg · Pull Request #34708 · ArduPilot/ardupilot · GitHub
  • Remove pre-4.2 aux function entries from the parameter documentation
  • Merged!
UTC0031 - EKF3: fixed GPS glitch handling for yaw reset by tridge · Pull Request #34714 · ArduPilot/ardupilot · GitHub
  • Fixed GPS glitch handling for yaw reset
  • Hand-launch in FBWA
    • Kind of squirrelly
  • Tridge will have anothher look based on Randy’s feedback
UTC0039 - AP_OSD: add 53x20 canvas size and fix canvas reply screen tracking by Hwurzburg · Pull Request #34718 · ArduPilot/ardupilot · GitHub
  • AP_OSD: add 53x20 canvas size and fix canvas reply screen tracking
  • Merged!
UTC0040 - Convert lua binding generator to python by tridge · Pull Request #34723 · ArduPilot/ardupilot · GitHub
  • Convert lua binding generator to python
  • Bytewise output-identical to the old generator
  • MergeOnCIPass
  • Jinja?
    • No, tridge used a built-in templating engine
    • Tridge hasn’t used jinja
    • Could use empy
UTC0047 - AP_OSD: initialise param setting lookup state by Hwurzburg · Pull Request #34737 · ArduPilot/ardupilot · GitHub
  • Initialise param setting lookup state in OSD
  • A few formatting requests
  • Fixes a segfault which is good!
UTC0056 - GCS_MAVLink: prevent stale MAVFTP requests from consuming sessions by amilcarlucas · Pull Request #34296 · ArduPilot/ardupilot · GitHub
  • Fix stale ftp session problems
  • Conflicting badly
  • Interesting movement of ListDir command handling around
  • Increased parallelism is nice!
  • Why is this draft?
UTC0104 - close
