Dev Call Nov 2, 2026
CI Workflows
Release Update
AI review
Issues & Pull Requests
https://github.com/ArduPilot/ardupilot/pull/33617
https://github.com/ArduPilot/ardupilot/pull/33816
https://github.com/ArduPilot/ardupilot/pull/34070
https://github.com/ArduPilot/ardupilot/pull/34334
https://github.com/ArduPilot/ardupilot/pull/34351
https://github.com/ArduPilot/ardupilot/pull/34419
https://github.com/ArduPilot/ardupilot/pull/34504
https://github.com/ArduPilot/ardupilot/pull/34599
https://github.com/ArduPilot/ardupilot/pull/34728
https://github.com/ArduPilot/ardupilot/pull/34737
https://github.com/ArduPilot/ardupilot/pull/34759
https://github.com/ArduPilot/ardupilot/pull/34771
https://github.com/ArduPilot/ardupilot/pull/34804
https://github.com/ArduPilot/ardupilot/pull/34823
https://github.com/ArduPilot/ardupilot/pull/34829
https://github.com/ArduPilot/ardupilot/pull/34839
https://github.com/ArduPilot/ardupilot/pull/34864
https://github.com/ArduPilot/ardupilot/pull/34869
https://github.com/ArduPilot/ardupilot/pull/34872
https://github.com/ArduPilot/ardupilot/pull/34880
https://github.com/ArduPilot/ardupilot/pull/34937
https://github.com/ArduPilot/ardupilot/pull/34940
**CI Workflows**
**Release Update**
**AI review**
**Issues & Pull Requests**
Attendee count (max): 14
UTC2300 - pre-agenda
  • AI reviews are almost all green/approve, no red ones
  • Admin-vs-non-admin supportproxy stuff
UTC2301 - CI Workflow runs · ArduPilot/ardupilot · GitHub
UTC2305 - release update
  • Randy would like 4.7.3 out the door
    • There are several approvals on it
    • Vibration failsafe is the biggest issue
    • Going out today!
UTC2310 - https://github.com/ArduPilot/ardupilot/pull/33614
  • Morakot fixes
    • Probably need a sanity check in hwdef so that if you have an analogue backend then you must have fonts
  • Needs fonts…
UTC2314 - AP_HAL_ChibiOS: add BlueBerry_H743 Wing flight controller by sunyanmeng963 · Pull Request #33617 · ArduPilot/ardupilot · GitHub
  • BlueBerry_H743 Wing flight controller
  • Need to only reserve 10 IDs
UTC2315 - AP_HAL_ChibiOS: record and resume accesses trapped by low-memory protection by peterbarker · Pull Request #33816 · ArduPilot/ardupilot · GitHub
  • Record and resume access trapped by low-memory protection
  • Lots of information when things go wrong on low memory access
  • We keep going but log a bunch of stuff and raise an internal error
  • Can be merged after bench test
UTC2324 - Copter: clear takeoff spool-up block on boards without ESC telemetry by yuiseki · Pull Request #34070 · ArduPilot/ardupilot · GitHub
  • Allow copter to take off if hal-with-esc-telem not compiled in
  • Randy will probably merge
UTC2327 - hwdef: add board support for AcctonGodwit_GFH7 by BrianChang1212 · Pull Request #34334 · ArduPilot/ardupilot · GitHub
  • Acton goddwit board gfh7
  • Merged!
UTC2331 - Plane: rework fbwa glide failsafe by IamPete1 · Pull Request #34351 · ArduPilot/ardupilot · GitHub
  • Rework fbwa failsafe
  • Weird things where behaviour behaves differently depending on how you enter the failsafe
  • Probably a new mode just for the failsafe
  • PH will chase that
UTC2339 - ChibiOS: allow mcu monitoring without external ADC pins by IamPete1 · Pull Request #34599 · ArduPilot/ardupilot · GitHub
  • Allow MCU monitoring without external ADC pins
  • Merged!
UTC2341 - Group EKF3's fusion state into objects by peterbarker · Pull Request #34728 · ArduPilot/ardupilot · GitHub
  • Create little objects to hold different distinct fusion states
    • E.g. body drag, optical fusion
  • merged!
UTC2346 - AP_Bootloader: Add board_id for YARI V6S by KarthiAru · Pull Request #34504 · ArduPilot/ardupilot · GitHub
  • Reserve board IDs
  • Merged!
UTC2347 - AP_OSD: initialise param setting lookup state by Hwurzburg · Pull Request #34737 · ArduPilot/ardupilot · GitHub
  • AP_OSD: initialise param setting lookup state
  • Merged!
UTC2349 - waf: use Picolibc libc on ChibiOS (keep newlib libm) by tridge · Pull Request #34759 · ArduPilot/ardupilot · GitHub
  • Use picolibc libc on ChibiOS
  • Keeping libm
  • Currently we have the abort() symbol in the code and we can permanently lose large chunks of memory with various paths in the current libc we use
  • abort() becomes blacklisted
    • No locking in libc now
  • Not across all HALs, just ChibiOS and SITL
  • Want to match existing performance
    • Copy math functions which were performance regressions
    • Lots of different floating point models involved
      • E.g. M4 m7 double/single hardware
  • Want Thomas to look at this
UTC0003 - Correct compilation bugs when heli involved by peterbarker · Pull Request #34804 · ArduPilot/ardupilot · GitHub
  • Correct compilation bugs when heli involved
  • Merged!
UTC0006 - hwdef: document BRD_IO_DSHOT for IOMCU DShot outputs by Hwurzburg · Pull Request #34823 · ArduPilot/ardupilot · GitHub
  • Document BRD_IO_DSHOT for IOMCU Dshot outputs
  • Corrects some declarations of what things are available on each board
UTC0008 - https://github.com/ArduPilot/ardupilot/pull/34829
  • Add support for remote power off
  • Can be merged once the power off is done
UTC0014 - Plane: finalize throttle before tiltrotor output by Hwurzburg · Pull Request #34839 · ArduPilot/ardupilot · GitHub
  • Finalize throttle before tiltrotor output
  • Maybe this is right but it changes the order of a lot of stuff, making PH nervous
  • PH wants to fix it properly eventually
  • Would need to do some realflight testing of this with various tiltrotors
  • Motortest?
  • PH will get to this eventually
    • Tidy up how throttle output is done
    • Should be much easier to understand after that
  • Tilt-rotors not biding throttle min / throttle max
  • Has been like that since forever
  • So no huge rush
  • But should fix for next stable
UTC0018 - AP_HAL: respect the port lock when changing UART line settings by j-w9 · Pull Request #34864 · ArduPilot/ardupilot · GitHub
  • Leave a locked RC UART alone during serial passthrough
  • Elrs passthrough flashing not functioning properly
  • 1-second reset
    • Very small amounts of data drop
    • Corrupted flash
    • A few small fixes allowed for reliable flashes
  • Maybe a more general solution would be good?
  • Review and request changes left
UTC0030 - AP_Periph: add PRX port and baudrate default defines by Hwurzburg · Pull Request #34869 · ArduPilot/ardupilot · GitHub
  • Add PRX port and baudrate default defines
  • Fixes L431 periph
  • Merged!
UTC0035 - hwdef: remove unused netmask and serial baud defines by Hwurzburg · Pull Request #34872 · ArduPilot/ardupilot · GitHub
  • Remove unused netmask and serial baud defines
  • Merged!
UTC0036 - AC_AutoTune: preserve start rate sign in negative rate tests by LostPatrol · Pull Request #34880 · ArduPilot/ardupilot · GitHub
  • Preserve start rate sign in negative rate tests
  • Merged!
UTC0038 - GCS_MAVLink: restore port thread ownership when serial passthrough ends by harshalsp07 · Pull Request #34937 · ArduPilot/ardupilot · GitHub
  • Restore port thread ownership when serial passthrough ends
  • Tridge wants to remove is_owned_by_current_thread
    • He thinks the uart locking is now correct
  • Can be merged once CI passes
UTC0043 - Plane: autoland: constrain roll in landing by IamPete1 · Pull Request #34940 · ArduPilot/ardupilot · GitHub
  • Constrain roll in auto landing
    • Makes it the same as auto mode
  • merged
UTC0044 - Stop emitting jammed GPS position from EKF3 by peterbarker · Pull Request #34958 · ArduPilot/ardupilot · GitHub
  • Stop emitting jammed GPS position from EKF3
  • Fixes really bad position emitted in DeadReckoning
  • Merged!
UTC0050 - conference
  • Please send links to presentations to Randy or whoever
  • The conference went well!
UTC0052 - close
