Copter
- 3.5.4 release progress
- New Loiter (from Leonard)
- Flight mode object change for Copter (from Peter Barker)
Plane
- 3.8.3 release
General
- apj tool
issues
Copter
Plane
General
issues
Attendee count (max): 20
Pre-agenda:
Short discussion of https://github.com/ArduPilot/ardupilot/pull/6998
MO is now aware and can do something about it!
23:05 - Randy and Copter
3.5.4
Its out and tested
Compass IST8310 is not working
Is this behind the minimise-features macro?
Jordi explicitly said v2
4 fewer compass drivers on v2
Right on the edge for being able to put v3 onto bodgy old processors
MO: v3 gets loaded onto board that have 2mb flash. if its less, v2
Anything with this on it should be able to take the v3 firmware!
https://store.mrobotics.io/mRo-GPS-u-Blox-Neo-M8N-HMC5983-Compass-p/mro-gps003-mr.htm
LIS3mdl also doesn’t seem to work
V2 and v4 firmwares
Problem that the devs don’t appear to have the modern GPS/compass units to test on
Leonard has been working on a new loiter controller
Has reworked it since last tested
Should have a very direct feel
Directly controls lean angles
Feels like alt hold
Still has a brake in it
Actively comes to a stop
Should be able to replace poshold with this
But Randy’s not confident everyone would be happy with that
So he won’t be trying to force people off poshold
Maintains a desired velocity/position
Acceleration control
Extra prediction for accelerations
Actively estimating where vehicle will be based on desired acceleration
Old new loiter never made it in
SkyRocket guys didn’t like it that much
Randy liked it!
Available in Leonard’s repo
https://github.com/lthall/Leonard_ardupilot/tree/20171004-new-loiter-ac353
Based on something quite old - August 9th
2000+ commits behind…
Probably worked off old-new-loiter
Flight-mode-objects
[10:22 AM] (Channel) khancyr: rover is the most up-to-date now
[10:22 AM] To Weekly devcall: Not for long!
Randy’s working on top of Peter’s branch, moving some more stuff from AttitudeControl
10:22am - Rob and compass issue
Total field changing on long runs
Bug in silicon?
Physical effect?
AC3.3
Ancient
Difficult to work with logs from this old code
Reproduce on something more recent?
Difficult to do legally
EKF1
Temperature issue
Need to look at innovations
Use world magnetic model to show what sensor should give
Should be visible over shorter distances
10:32 - tridge and Plane 3.8.3
Tailsitter things
New transition code is working very well for a lot of people
Each actuator needs to have separate speed-scaling
Propeller-blown vs non-propellor-blown
Servo_n_flags?
Lots of control surfaces!
Inc. canards
Speed-scale elevons if they’ve got airflow from pops
Speed-scale left-elevon with lef-throttle and right-evelon with right-throttle
Don’t speed-scale elevons out on edge on throttle but based on airspeed
Maybe need another model?
Don’t want our parameters to be a separate programming language!
Hover / fast-forward-flight-hover
Lean plane over hard in qhover also needs speed scaling!
What level do we do this?
Saturation?
Overall-throttle speed scaling is already in
Throttle + airspeed and control surface speed scaling will be a major feature of next version
Next major release will be 3.9
Dual airspeed support
More point releases (3.8.4) may happen before then
depending on what’s found
Tilting quadcopters?
Wingless quadplane?
Better to do it in ArduCopter
No lifting surfaces
Shouldn’t be that hard to do it in Copter
AHRS view code
Using motors backend would be a lot of work
Better to do stabilisation in frame of rotors
And allow IMU to be tilted in flight
Servos don’t tilt servos, they tilt the IMU….
Will let current code all work
Rotating AHRS may not account for loss of control in some axes when you tilt the rotors
betaflight
Kk boards just do rate but supported it a long time ago
Amilcar’s company is up to shenanigans to do with odd airframes
When these things get real lifting surfaces tridge is interested
Or when you’ve got a subset tilting etc
If the motors go all the way forward then you lose roll control
Need control surfaces
10:47am - apj tool
PR is in
Frame-specific-firmwares done right?
Uses a fixed 8k of flash
Could make it smaller on some boards
2k on v2?
Playing linker tricks to minimise code size proved to be difficult
Tools/scripts
Need to start using it on the servers
Should be good for OEMs
Can give customers a “binary” which sets customer params
E.g. Rob’s helis
E.g. BlueRobotics subs
Stable releases required before this will be useful
Defaults.parm requires recompiling the firmware
This doesn’t need it
Will deprecate or remove old mechanism
--show
will dump content of 8k
These override the standard ardupilot defaults
Won’t override variables which the user has set
Could have a parameter which forces the variable from the 8k section?
10:55am - Rob
Integration of Iris Automation
Computer vision system
Collision avoidance for drones
Machine learning
Can see aeroplanes
Keen to work with us
Fnoop might be a good person to work with them?
Already lists APM…
ROS activation, apparently
Pierre?
Monocular camera
Rob will get them in touch with tridge and Peter
11:02am - issues
A change in loop rate requiring a reboot is OK
Memoising it would be fine
Camera trigger distance mission item
Taking over in guided/cruise would still have camera firing
This one-parameter approach is simpler
Low-cost in code
Good idea
Will be merged
Has been merged
Wants feedback on this one
Every battery instance gets a separate failsafe
Thrust scaling on a per-battery basis would be good
Another PR allows you to specify which battery
BATT_FS_VOLT_RC
Sag compensation thing
https://github.com/ArduPilot/ardupilot/pull/7213/files#diff-6e0e45f93b8363a45744f3354300ec0bR84
Seems good to tridge
Critical vs non-critical
Would benefit from the per-vehicle-parameter-annotation PR
Every vehicle will have the same set of battery failsafe triggers
Jacob: We have a SURFACE mode
MO will be working on MP to have it not die
Stale but refreshed
Will allow proximity be added to rover
Needs FF’s issues to be addressed
Khancyr has indicated he can work on it again
Very interesting from amilcar’s perspective
11:21am - Contribution of the Month
Needs somebody on point to look after it
JP is suggesting some nominations should occur
CO and BG will be nominated for the heli work
JP will create a google voting form for nominations
and an email
Should we limit number of times it can be won by a person?
Once for all time?
General agreement on call
But need a discussion on the mailing list
Maybe once every 2 years?
FF: Ever might leave us with no one to attribute it to
RL: wouldn’t the voting tend to favour those that haven’t won?
Didn’t seem to work that way
MdB: But in that case maybe not giving it is fine?
MdB: The main concern is that by virtue of being the only person elgible (ie made a change and hasn’t gotten it) isn’t always worth the prize (IE small wiki change)
11:29am - reversed parameter at boot and Copter
DDVP only, of course
Claim that there’s a safety issue
CO showed a good demo of it
Changed reversed parameter while heli was live
Should it not take effect ‘til reboot
Tridge wasn’t convinced
Electric planes have had this forever
Set reversed and the thing goes
May confuse setup as ESC malfunctioning on reboot is harder to diagnose than when things take effect straight away
Many parameters can be changed to get the same effect of this reversal
E.g. pwm-min
Would need special-case code for this functionality in the servo library
Maintenance cost
RL thinks a reboot should be required
He understands that there’s many ways this can happen
But that we can fix this one
Currently contained in the heli rsc stuff
But stuff should be moved to be in the servo-output stuff
BG: But the pass-through stuff requires PWM
Tridge: you can do pass-through
But better to be able to use scaled input/scaled output so the output range doesn’t have to match your input range
Even in manual pass-through
When Rob wrote it he assumed off-pwm of 1000 and 2000 as full-speed
No need to reversing etc etc
Tridge current stuff handles much more than 1000-2000 outputs
RPM feedback from motors is what we really need
RL wants to retain the option of reversing ESC
1500 for disarm
Rebooting can be problematic
Will start spinning
[11:45 AM] (Channel) JW: The pulse gets cut short
[11:45 AM] (Channel) JW: and interpreted as a shorter pulse
[11:46 AM] To Weekly devcall: @Jaconb did your patches “fix” that?
[11:46 AM] (Channel) JW: As far as I can tell
[11:46 AM] To Weekly devcall: Well we should damned well get that merged, then… maybe I can convince Dale to test that out at the field.undefinedundefinedundefinedundefined
